06-27-2016, 07:00 AM
#281
I'm considering opening up my muffler, enlarging the holes where the pipes enter, thus making what could pretty much be called an internal Pedro mod.
Drilling by the red arrows would allow the exhausts to follow the blue arrows into the outlet.
Would that work? It would be a fairly easy mod to make, provided you're able to weld or get someone to do it for you. It would also look completely stock from the outside.
Reason: Wrong picture...
07-20-2016, 02:52 PM
#282
2002 Boxster S
Originally Posted by DWBOX2000
Just wondering now that some time has passed, is everyone still happy with their choice of drilling out? Some other sites were saying it made the boxster sound more like a japanese car
Yep, still happy with 3/8" holes. It doesn't change the sound a lot -- it just adds rumble, mainly. It's not going to wake up your neighbors or turn heads when you leave cars & coffee. It's a subtle change, but worth making.
2009 Carrera S cabrio
10-22-2016, 05:09 PM
#283
How long does the drill bit need to be?
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
10-22-2016, 05:37 PM
#284
still plays with cars...
Check the first post... it shows what tools were used. It doesn't appear to be an extra long bit.
Six speed 2000 Boxster S
10-22-2016, 09:41 PM
#285
2002 Boxster S
I used 24-inch (60cm) drills. Anything shorter will not reach the spot that needs to be drilled.
11-01-2016, 08:23 AM
#286
98 Arctic silver 986
https://www.youtube.com/watch?v=PO9l-X4eUOk This guy made a great how / before and after video. He even gives a shout out to Particlewave
11-30-2016, 07:06 PM
#287
2ndary cat delete and 2x 1 inch holes. No drone but still too quiet. I might go 2x 1.5 inches or maybe 2 additional holes....
12-09-2016, 01:36 PM
#288
Originally Posted by tommy583
Ha! That's funny
I did this mod at the same time that I de-snorkeled and I thought the increased sound was nice, though mild. I'm now convinced that the muffler mod did little or nothing at all, as others have reported on the 2.5, and the increased sound was primarily from the intake.
I can confirm that the 2.5 muffler on my '99 is full of sound deadening material, rendering this mod virtually pointless.
I might crack it open some day to see what can be done.
12-09-2016, 06:37 PM
#289
Or maybe all of the pictures of opened mufflers have just had that material removed before the picture? Can anyone who has opened one confirm or deny?
Edit: I went ahead and enlarged the holes from 1/4" to 3/4" and it did increase low end rumble, though not as dramatically as I'd hoped.
12-10-2016, 04:23 PM
#290
Crios + PSE = ?
Wonder what Crios mod is like if you add the Pedro Sport Exhaust mod?
'01 986S: LN IMS, PedroBar, PSS9 coil-overs, underdrive pulley, 997 short shift, GT3 console delete, Crios muffler mod
12-10-2016, 05:50 PM
#291
I'm finally happy with sec. cat delete. 2 holes each pipe. 1.5 inch and 1 inch holes on each side. No drone and decently loud. 03 2.7
12-10-2016, 05:54 PM
#292
I'm going to go right through the top of the muffler and into the inlet pipe with one or two 1" holes.
12-10-2016, 08:27 PM
#293
I sold a crios modded muffler to a buddy who sent it to Fister. They do a mod similar to the Pedro exhaust. I don't know if they closed the crios holes back up or not, but it sounds pretty awesome now.
12-11-2016, 09:29 AM
#294
Ben-Auto-Design
It's a common mod that I've been told works very well. One or two 15mm holes.
You don't have to open the whole exhaust, just open a window on both sides.
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
12-20-2016, 02:31 AM
#295
Thread needs more pics for us 97 to 99 Boxsters. I need to see where exactly to drill the holes.
1998 Porsche Boxster 986 Convertible.
12-20-2016, 04:50 AM
#296
i wonder if you could go in via the entrance pipe to drill the holes - similar to the crios mod?
if you do as you say, perhaps a couple of 3/4" knockout plugs to fill the hole - no welding required, do it while the muffler is in the car?
12-20-2016, 05:58 AM
#297
I'm not completely convinced that it does anything on the earlier mufflers because of the sound deadening material inside.
I will definitely look into this. It will be after the 1st of the year before I get to it. If I can't get at it from the inlet, I'll go through the top (don't want the plugged holes to be visible from the bottom).
12-20-2016, 06:02 PM
#298
Any 98ers on here that have made this modification?
Does it work?
01-01-2017, 07:16 PM
#299
better idea
Do what everybody else told me I couldn't do cause it wouldn't fit....I installed headers and intermediate pipes from a 06 Cayman and the mufflers already had the secondary cats deleted. My Midas dealer cut and rotated the pipes a little for clearance with no issues. I vinyl ty rapped the wheel sensor wiring to the struts far from the exhaust..wa la! Still there. Sounds great and a steal for a $1000. Sounds way better than Fabspeed. I heard one and thought it sounds the ****************s!
01-01-2017, 07:30 PM
#300
It's "voilà", lol (parlez-vous français?)
Only $1000?
Glad you like it, but that's crazy expensive. You could have had bypass pipes bought and installed for less than $200.
