Old 05-29-2008, 10:29 PM   #1
Anyone interested in a radiator fan hack?
I've seen it on Rennlist and I'm going to go it to my 01' S this weekend. Anyone interested in pictures and directions?
Old 05-30-2008, 04:08 AM   #2
Sure. (What's a radiator fan hack do?)
Old 05-30-2008, 10:16 AM   #3
It allows you to manually turn the radiator fans on/off as well.
There is also a mod to manually turn the engine fan on/off as well.
I'm going to build a cheesy set up at first until I can order custom switches that look OEM.
Here is the idea behind it,posted from a guy on Rennlist
Needle at right side of 180 means your temperature is 215F+. Goal is to keep the temperature below 200F which is easier to address while temps are low rather than having to cool it down to that level.
Old 05-30-2008, 02:22 PM   #4
Okay, sure, I might be interested in doing something like that. Post away!
Old 05-31-2008, 11:06 AM   #5
There Is No Substitute.
rick3000's Avatar
I would also be interested! Could you post a link?
Old 06-02-2008, 07:36 AM   #6
Why not just change the 'stat that controls the fans and use a lower temperature?
Kevfra is offline   Reply With Quote
