Old 05-30-2008, 10:16 AM   #3
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by Frodo
Sure. (What's a radiator fan hack do?)
It allows you to manually turn the radiator fans on/off as well.
There is also a mod to manually turn the engine fan on/off as well.
I'm going to build a cheesy set up at first until I can order custom switches that look OEM.
Here is the idea behind it,posted from a guy on Rennlist
Needle at right side of 180 means your temperature is 215F+. Goal is to keep the temperature below 200F which is easier to address while temps are low rather than having to cool it down to that level.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
