Old 01-02-2008, 05:25 AM   #1
DIY" Drive Belt
Drive Belt.
1) Move seats forward and remove carpet from behind seats.
2) Undo the nuts and bolts that fix the metal cover to the front of the engine to expose the front of the engine.
3) Use a 15/16 wrench and turn clockwise on the adjuster to loosen the belt tension. Simply peel off the belt and be sure to route the new belt the same way.
4) Make sure that the new belt is sitting correctly in the grooves before starting engine to test.
kouks is offline   Reply With Quote
Old 01-23-2008, 05:42 PM   #2
Thanks for the photos and write up!
I did my belt service the other day and it was very EASY to do.
The whole procedure, from start to finish, took less than 45 minutes.
Gary
Seattle, WA
2000 Boxster S
Ferrari 550 Maranello
Subaru Outback DD
SeattleBoxers is offline   Reply With Quote
Old 01-23-2008, 05:46 PM   #3
Finally a picture that shows the Cover with the Bolts still visible, i never wanted to remove it cause no one would show a picture of that in there DIY's
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 01-23-2008, 06:46 PM   #4
Great photos. Thanks. It looks like a very easy diy. I've seen recommendations about sketching the layout of the belt before you remove it, so you don't screw up the routing.
Anyone have any suggestions on when it should be replaced? How many miles are you getting before replacement? I've got 56000 on my 01 and am thinking just for preventitive maintenance I ought to replace it. Is the belt like tires... gets bad just from age? If so, I think I probably need to change it soon. Especially, given the apparent ease of doing so. ok ok... so I'll go look it up in the owners manual. Practical advise would be appreciated though!
Bob
79 911SC Targa.. gone but not forgotten
2001 Boxster Black/Savanah Beige
RoW M030 suspension
7/15 mm spacers
Deambered
Desnorked
SS door sills
Debadged
Clear tails
Technobrace
Technobra
I'll never own another black car!
Bob O is offline   Reply With Quote
Old 01-23-2008, 07:43 PM   #5
Nice DIY kouks!
dcporsche99 is offline   Reply With Quote
Old 01-24-2008, 03:27 AM   #6
When you remove the service cover watch out for the sharp edges.
Old 01-27-2008, 12:29 PM   #7
Bob
Here a the photo of the belt path from my service manual.
I highly recommend that any DIYer buy a copy of the Bentley publications Boxster service manual.
Gary
Seattle, WA
2000 Boxster S
Subaru Outback DD
Old 01-27-2008, 03:07 PM   #8
Thanks for that Seattle. Very helpful
Bob
RoW M030 suspension
7/15 mm spacers
Deambered
Desnorked
SS door sills
Debadged
Clear tails
Technobrace
Technobra
Old 06-19-2008, 07:03 AM   #9
how tight should the belt be
mentions loosening the tension to remove the belt, but how tight should it be to operate?
cheers
ralphie is offline   Reply With Quote
Old 06-19-2008, 07:27 AM   #10
The tensioner is spring loaded and self adjusting.
Old 06-19-2008, 08:16 AM   #11
just was thinking about it and thought that it would self adjust!
thanks
