Old 10-15-2007, 01:13 PM   #2
Send a message via Yahoo to Chills
You are exactly right. You need to connect the wire that turns on the amp. Your new radio should have a wire which you can connect to the factory harness.
I had the exact same problem with my Pioneer AVIC. Its a simple fix.
I bleed green
It's not about the summit, it's about the climb.
http://i133.photobucket.com/albums/q46/chills1138/2.jpg
Chills is offline   Reply With Quote
