Old 07-31-2022, 03:11 PM   #1
Fresh air driver vent
Have a 986 endurance race car and really struggle with how hot it gets in the cockpit. Anyone come up with a good solution for a fresh air vent for the driver? In my miatas I use a naca duct in the front side window which blows a tremendous amount of air on the driver and really helps a lot.
subieworx is offline   Reply With Quote
Old 08-01-2022, 03:37 AM   #2
1998 Boxster Silver/Red
1. Roll down windows
2. Top down
3. Bags of ice on groin area
4. Donna D'Errico in the passenger seat
5. Fashion NACA ducts to the ragtop
Not necessarily in that order.
1998 Porsche Boxster
Old 08-01-2022, 07:27 AM   #3
78F350's Avatar
Have you looked at ducting it from under the dash? I have no idea how your interior is configured, but there are two decent sources from just below the windshield to flow air:
Old 08-01-2022, 07:38 AM   #4
That's a great idea. I've pulled the center... the foam repair job... and am thinking you could remove the guts... the flaps... cut a hole or two in the hood, and ram-air it. It seems that could give a nice breeze, when moving. Likewise pulling the cabin filter and ducting it to a ram-air on the hood.
Old 08-01-2022, 03:47 PM   #5
rastta's Avatar
I put two vents in my Boxster with hoses to the interior from those vents. You don't need to do any scoops - the air gets sucked in well enough. It uses 3 in hose. The ducts were from here and required no modifications other than to drill the holes in the factory screw locations.
https://www.pegasusautoracing.com/productselection.asp?Product=3623
rastta is offline   Reply With Quote
Old 08-02-2022, 10:49 AM   #6
Very nice! Are those holes cut in your hood I see as well?
Old 08-03-2022, 10:20 AM   #7
rastta's Avatar
Well yes and no. The hole is for the air jack feed that is right in front of the vent. There are no holes for the vent. It functions as the feed of the heating and air system would - air gets suck under the hood and into the cabin. It's amazingly functional. I was thinking of adding inline fans at first - but they are unnecessary.
Old 08-04-2022, 06:27 AM   #8
Lemming's Avatar
I used a similar setup in my 944 race cars, the cowl induction is fantastic, lots of air. Just remember to cover it when it's raining!
Just as an FYI, that modification is not allowed in PCA SPB racing. I wanted to do the mod when I built may car and had a long discussion with Walt F. at PCA. Below is part of an email response to me.
"Tim - none of my rules committee colleagues are in favor of allowing any openings in this cowl/battery tray area to be used for cabin ventilation if the stock components are removed. I don't doubt that having these openings will move air into the cabin, but there are other ways to get it."
To get around this, you could easily make a plate to cover the openings when racing with PCA. Again from Walt:
"So your removable plate sounds like the way to go."
Tim
1998 986 (3.2L and 6-speed transmission added)
1999 986 (SPB)
1999 986 (parts car)
2001 986 S (parts car)
Lemming is offline   Reply With Quote
Old 08-04-2022, 09:40 AM   #9
rastta's Avatar
I kept the factory covers and just use those if it's raining.
