Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 01-20-2018, 04:43 AM   #1
truegearhead's Avatar
Boxster Front Suspension Design Category (For Classing)
NASA's new Time Trial rules impose a penalty on cars with upper a-arms of wishbones. As an example they list Miata's, S2000s and Boxsters however I don't believe Boxster's fit into this category.
"2) If the vehicle has an OEM suspension design utilizing an upper “A-arm” or
“Wishbone” type control arm on either the front or rear suspension, a Modification
Factor will be assessed. Conversion from an alternate design to an “A-arm” or
“Wishbone” suspension design using non-OEM parts is not permitted
(front or rear)."
Miata
S2000
Boxster
I think they may have gotten confused with the 996 which does have a wishbone (or virtual a-arm) rear suspension
What do you guys think? Whats the best way to approach this argument? The penalty for a-arms is huge, almost twice as much as aero.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 01-20-2018, 04:56 AM   #2
My college professor wouldn't be proud but I'm going to bring Wikipedia in as a reference. Wikipedia defines a-arm suspension as a design that uses a top and bottom arms to control the position of the wheel. Boxsters on the other hand rely on the shock assembly to control the location of the wheel. I think this is the key difference.
"An automobiles, a double wishbone suspension is an independent suspension design using two (occasionally parallel) wishbone-shaped arms to locate the wheel. Each wishbone or arm has two mounting points to the chassis and one joint at the knuckle. The shock absorber and coil spring mount to the wishbones to control vertical movement. Double wishbone designs allow the engineer to carefully control the motion of the wheel throughout suspension travel, controlling such parameters as camber angle, caster angle, toe pattern, roll center height, scrub radius, scuff and more."
2003 911 C2
Old 01-20-2018, 08:21 AM   #3
yup, struts all around on this car, so definitely a misclassification
Old 01-20-2018, 08:56 AM   #4
I agree, the Boxster is misclassified. The Boxster is (somewhat embarrassingly) a pure strut design.
Old 01-20-2018, 04:29 PM   #5
Absolutely misclassified.
ST5 rules seem curiously gerrymandered to -> Miata's
I gave up with all the hp penalties, etc. A 2.5 doesn't really have a home in our NASA region unless you have a weak field in GTS2.
MaxD is offline   Reply With Quote
Old 01-20-2018, 05:24 PM   #6
It’s an odd rule set for sure. For me the e36 M3 seems to be the car they’re making for the class. Especially considering the weight/tire limits, step mid-engine penalty, and a-arm penalty and that little waiver for allowing subframe reinforcement without penalty (which only e36s benefit from)
2003 911 C2
Old 01-21-2018, 08:21 AM   #7
One thing is sure, no one seems to be happy with the rules (e36 M3 guys too).
Old 01-21-2018, 09:55 AM   #8
Track rat
Topless's Avatar
Somebody is overthinking suspension during NASA rules making process. 99% of this game is wt/hp, wt/grip, and setup. Everything else is window dressing.
Old 01-21-2018, 01:26 PM   #9
I’m glad it’s not my job, rules can’t be an easy thing but it does seem they made it harder than it had to be. I am thankful I won’t need to take that 4 wheel drive penalty, which at this class power level is doing very very little.
What are the M3 people upset about?
2003 911 C2
Old 01-22-2018, 06:32 AM   #10
Mostly it pertains to having run a rather noncompetitive TT4 car last year then having to ditch aero, add weight or detune to fit into TT5 or pony up the $$$ to be competitive in TT4.
The new tire width rules are not cheering anybody up either.
I'm just glad my M3 fits into ST3/TT3 with its much simpler rule set. For the Boxster I'm still undecided what to do.
Old 07-13-2020, 08:35 PM   #11
Who's askin'?
maytag's Avatar
Max, are you still running in nasa at all?
I'm thinking about going time trial racing.
Waddya think, with my car: TT4?
Old 07-14-2020, 11:00 AM   #12
I raced the first two NASA events. Tim and I were killed by real GTS2 cars that came out from Colorado over the first Outer track weekend. We are now thinking of running the SPBs in ST5 since we basically will have our own group and now really don't have to make any changes to meet class with the rules as they are today.
Your S could easily be ST4/TT4. It is super competitive in NASA Utah.
You can take out quite a bit of weight I bet.
We need to have a Boxster dyno day!
PCA Intermountain Region Track Chair
SPB #50
Old 07-14-2020, 12:34 PM   #13
Who's askin'?
maytag's Avatar
Looking at the results from last weekend, my lap times (best was 1:49) would slot in 7th among the TT4 guys. The lap times range from 1:43 ("Team Hemisphere Racing" in an M3) to a 1:57. The only Boxster I see in the TT4 results is John Taylor's spec box. My lap times were 2.5 seconds faster than his, which might be all about power, with his SPB vs My 'S' with mods.
I kinda like that in TT4 I'd have some room to go learn some things.
I sent an email off to Matt Guiver. the website says I need a "NASA PAssport" showing I;ve been signed-off for each of the DE groups. But I sure can't find anyting about that NASA Passport anywhere else on the Utah region site. And I sure don't have one! haha.
Hope you're well.
and YES! We DO need a Boxster Dyno Day! Soon!
Old 07-14-2020, 03:23 PM   #14
Breaking 1:50 on East is great. That is a major barrier, good job.
Just buy your TT licence from NASA National and shoot Matt an email to approve it.
SPB #50
