Old 03-21-2020, 11:45 PM   #1
Coilovers
Hi I’ve fitted some coilovers to my 986 3.2s
Can I ask what length spring others are running. I’m currently running 6” springs but even with the car set at standard height I only have an inch of travel before it’s on the bump stop.
I want to lower the car and have Air cups fitted to raise it over speed bumps etc
I can slide the shock body down inside the arms another 1” to give me more travel in the shocks but just wondered what length of spring most of you run
Blue99 is offline   Reply With Quote
Old 03-22-2020, 06:49 AM   #2
Who's askin'?
maytag's Avatar
I just installed ohlins coilovers, and the spring was 200mm (7.87").
What brand coilover did you install?
Old 03-22-2020, 05:03 PM   #3
I don't know if this is what you're looking for, but this is what I have in my notes for the Boxster Spec springs which mount on PSS9's. They are also a 6" spring.
Length: 152mm (6")
Usable Stroke: 98m / 4 inch
Max Stroke: 103.2mm / 4.06inch
Max Load: 825kgf / 1820lbs
Swift spring part numbers:
450LB: Z70-152-080 (448LB)
500LB: Z70-152-090 (504LB)
Old 03-23-2020, 08:52 AM   #4
Thanks 👍 so between 6 _8 inch seems about right.
Old 03-23-2020, 10:07 AM   #5
Who's askin'?
maytag's Avatar
Originally Posted by Blue99 View Post
Thanks so between 6 _8 inch seems about right.
So, that's a range of like, 30%. Is that helpful to you?
Old 03-26-2020, 06:25 AM   #6
Hi it’s helpful as in I know the 6’ springs I’m running is within the general size some people are running.
Old 06-10-2021, 05:18 PM   #7
Muskoka Minute's Avatar
What are the spring rates on your Ohlins?
Found the post where you have 450/500
Thanks Bart
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
