-   Boxster Racing Forum (http://986forum.com/forums/boxster-racing-forum/)
-   -   Coilovers (http://986forum.com/forums/boxster-racing-forum/77420-coilovers.html)
Blue99 03-22-2020 12:45 AM
Coilovers
Hi I’ve fitted some coilovers to my 986 3.2s
Can I ask what length spring others are running. I’m currently running 6” springs but even with the car set at standard height I only have an inch of travel before it’s on the bump stop.
I want to lower the car and have Air cups fitted to raise it over speed bumps etc
I can slide the shock body down inside the arms another 1” to give me more travel in the shocks but just wondered what length of spring most of you run
maytag 03-22-2020 07:49 AM
I just installed ohlins coilovers, and the spring was 200mm (7.87").
What brand coilover did you install?
thstone 03-22-2020 06:03 PM
I don't know if this is what you're looking for, but this is what I have in my notes for the Boxster Spec springs which mount on PSS9's. They are also a 6" spring.
Length: 152mm (6")
Usable Stroke: 98m / 4 inch
Max Stroke: 103.2mm / 4.06inch
Max Load: 825kgf / 1820lbs
Swift spring part numbers:
450LB: Z70-152-080 (448LB)
500LB: Z70-152-090 (504LB)
Blue99 03-23-2020 09:52 AM
Thanks 👍 so between 6 _8 inch seems about right.
maytag 03-23-2020 11:07 AM
Originally Posted by Blue99 (Post 613870)
Thanks [emoji106] so between 6 _8 inch seems about right.
So, that's a range of like, 30%. Is that helpful to you?
Blue99 03-26-2020 07:25 AM
Hi it’s helpful as in I know the 6’ springs I’m running is within the general size some people are running.
Muskoka Minute 06-10-2021 06:18 PM
What are the spring rates on your Ohlins?
Found the post where you have 450/500
Thanks Bart
