Old 01-07-2019, 09:57 PM   #1
Building a 986 S for SCCA CS Autocross for National competition
I debated long and hard about what class and car to build for a run at SCCA autocross and I settled on the 986 Boxster S as a dark horse for CS. (GRM thread) A search was put forth and I have finally purchased the victim, er "candidate" was located.
It's a 2000 Porsche Boxster S, Finland build, with 2 options: cruise control and the wind deflector. The PO added the correct stand-alone 18" wheels and it's otherwise a stone stock 138K mile example with complete service records including IMS, new clutch, and a 33K mile used transaxle all done at Porsche dealers. I paid less than the PCCB brake option for the 718 Boxster for the whole car.
Cue the intro video:
I'm going document everything about this build here and on YouTube. It's going to be a dedicated autocross car for C Street in SCCA and may dabble in P03 for PCA as well since there's good overlap. I will be attending the SCCA National Tour and ProSolo in Packwood this season and the end goal is my first trip to Nationals in Lincoln in 2020.
Javelin is offline   Reply With Quote
Old 01-08-2019, 11:36 AM   #2
I love this stuff! If you don't know Woody (itsnotanova) yet, follow his six months to live posting. Great stuff there too. Good luck and keep posting!
Jgkram is offline   Reply With Quote
Old 01-08-2019, 11:46 AM   #3
78F350's Avatar
Welcome to the forum. I've been following on GRM and glad to see you here now too. There's some great guys here who can answer ANY of your 986 specific questions and a whole lot more.
Old 01-08-2019, 05:06 PM   #4
Awesome man! I just bought a 2000 986 base in September for autox and hpde. I will be following your threads and progress!
phook is offline   Reply With Quote
Old 01-08-2019, 08:13 PM   #5
Congratulations and we look forward to following your progress!
Old 01-08-2019, 09:09 PM   #6
Thank you everyone. It's not my first Porsche autocross rodeo, I campaigned a 944 in PCA Improved for 2 seasons, but I am definitely looking forward to running this car.
I had the complete suspension redone, check out the video here: https://studio.youtube.com/video/9rm0gWH0Vis/edit
Old 01-09-2019, 05:32 AM   #7
Welcome aboard. I have a friend that races SCCA autocross down here in Texas and the key to winning is losing weight. There's only so much you can squeeze out of a M96 but there's a million ways to take some pounds off. Here's a video of him on a practice run.
Woody
Old 01-10-2019, 06:01 AM   #8
The suspension refresh is complete. New OE equivalent control arms front and rear as well as new rear CV axles as well as Koni Sport adjustable dampeners. Watch the video here:
Alignment did not go exactly the way I wanted. With fresh suspension in place -0.3* of camber was all we could squeeze. We tried every trick in the book, but that's all she wrote for now. We will run a few thousand street miles and maybe 3 events before checking again in case the suspension settles in. (Note - ballast was at 155 pounds in the driver's seat to split the difference between me and my codriver.)****Everything else dialed in nicely. 7.9* of caster, -1/16" toe per side in the front. In the rear we got-2.15* of camber and set toe at exactly 0" for now. I am going to run the front sway bar (thinking of picking up a 996.1 GT3 bar) and 235's on the front (for minimal sidewall flex) and if it starts to plow dial the rotation back in with rear toe changes. (Remember, it's a dedicated autocross car!)
The other really important bit: weight. The car in complete street trim including service records and owner's manual in the car, the radar detector system, the spare/jack/tools, and a box of spares in the trunk scaled at 2953 pounds, or only 98 pounds higher than the lightest factory curb weight. Considering we already have the 18" wheel setup, that's great! 811 pounds on each rear wheel, LF was 695 and RF was 636 for a F/R bias of 54.93% to the rear. (Top up, 1/2 tank of fuel.)
Now that it's home I'll pull all of the extra junk out of the car (and weigh it), clean it up and check for phantom weight (dirt and rocks hiding!), and replace the fluids. On the tire front, thinking of a 235/285 staggered setup on the Bridgestone RE71R's. The goal is the first Bridge City Autosports event of the season, 2/24/19 at Portland International Raceway. Come run with us!
Old 01-13-2019, 10:38 PM   #9
Time for the next episode of Project Porsche Boxster autocrosser.
This time it's time to put the Porsche on a diet. I pulled the box of spares out of the trunk for 18 pounds and the spare tire out of the nose for 30 pounds, bringing our fighting weight down to 2905 pounds. I still have the floor mats inside, the radar detector, and the phantom weight to get out of it plus taking the gas down more and the changing the muffler we're looking pretty good. The wind deflector is another 2 pounds as well!
2000 Boxster S - SCCA CS / PCA P03 autocross build
YouTube - PlaysWithCars
Old 01-15-2019, 06:50 AM   #10
Javelin, do you plan to change out your brake hoses? If so, are you going to go with OEM or OEM equivalent?
When I bought my car and got a PPI, I was told that the brake lines look like they are still original, which means at this point they are about 19 years old. I want to change them out, and the cost of SS is not much more then buying an OEM equivalent like ATE and OEM is more expensive then a set of SS lines.
I've tried searching around but there isn't many threads on this topic. I thought yours might be the best to ask this question since you are trying to stay in stock class and I know SS lines will bump you up.
Old 01-18-2019, 03:11 AM   #11
https://www.youtube.com/watch?v=b51vB2LsaEw
Frederiko is a fast driver, that yellow boxster was beast mode too! He is actually selling a very well prepared S that I’d buy without hesitation. He is jumping ship and buying a Miata :.(
Shawn
-1999 Boxster 3.4L swap/NHP Headers/Fabspeed maxflow/ Coilovers/GT3 arms/adj. rear toe links/Tarret front and rear bar/UIDS/UAOS
-2002 911 Turbo -JRZ RS Pro/GMG swaybars/RSS/Billet k16s/ Markski turbo inlet pipe, tune, 3” exhaust, intercoolers/GT3 seats w/red GT3 belts/CCW classics
Sveach756 is offline   Reply With Quote
Old 01-18-2019, 04:05 PM   #12
Racer Boy
Racer Boy's Avatar
Cool to see a Boxster being used for competition, especially in the PNW! I'm in Seattle, and track my 2002 2.7, but haven't done any autocrosses with it yet.
Just wanted to be sure, the 1/16" toe figure is toe-out, correct?
Looking forward to following your progress, Javelin.
Old 01-18-2019, 05:01 PM   #13
I am not planning on replacing the brake hoses at this time, but if I do have to I will have to use the OEM style rubber/PTFE versions. I have used SS lines on other projects, including track day cars, and never needed them nor got any actual measurable performance advantage from them. That said, can't hurt either.
Old 01-18-2019, 05:03 PM   #14
Awesome! Maybe I'll see you at an event this season. Yes, the toe is toe OUT.
Old 01-19-2019, 08:16 AM   #15
jmitro's Avatar
cool project.
you've obviously got a lot of experience, but 235/285 seems to be a huge difference in stagger. why not closer to a square setup and dial the handling with suspension tweaks? are you limited by class rules?
07 Porsche Cayman S speed yellow
87 Porsche 924S Carrera GT project/ 951 engine transplant
2015 BMW X5
jmitro is offline   Reply With Quote
Old 01-19-2019, 10:08 AM   #16
Originally Posted by jmitro View Post
cool project.
In SCCA C Street rules you have to run the stock wheel width, and I have the staggered 18x7.5/18x9 optional wheels. With the lack of spring force and front camber I will be lacking in the mechanical grip and tunability needed to run a square setup and really will need to just maximize tire contact patch at the detriment to everything else. Really good autocross setups are terrible on a road course and visa versa.
I did some testing last season in my CAM class Cobra with staggered wheels (17x9/17x10.5) and found that it performed better with a staggered 245/275 setup than with a square 275 setup (or a staggered 275/305 setup for that matter). Sidewall deflection started to make itself known. That's why I'm leaning towards the 235/265 over the 265/285 for now.
Old 01-20-2019, 04:52 AM   #17
jmitro's Avatar
gotcha, very cool
2015 BMW X5
Old 01-20-2019, 05:48 AM   #18
JayG's Avatar
Nice
You may want to consider going to 17" wheels
A little lighter and tires are much less $$
Old 01-20-2019, 07:34 AM   #19
Nice
It would be interesting to see which would improve the lap times. Slightly lighter wheels vs a wider contact patch.
Old 01-20-2019, 08:22 AM   #20
Who's askin'?
maytag's Avatar
Are you running commensurately larger / diameter tires? Or are you adjusting profile to maintain diameter?
I'd be interested in how that impacts autox. I'd think the smaller diameter might aid in accelerating from point to point in those lower gears. On the other hand, sidewall flex is probably a big deal too?
