09-26-2020, 08:05 PM
#1
Wow! Congrats.
09-26-2020, 08:11 PM
#2
Who's askin'?
Originally Posted by WizardSmokey
So cool! Well done!
09-28-2020, 06:50 PM
#3
That sounds absolutely incredible! Well done!
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
09-29-2020, 04:38 PM
#4
Shapeshifting Lizard-Man
I wish I could just upload the videos directly to here, like pictures do, but oh well.
First pulls on the road. Cooling system still needs some refinement, but for now, it's enough to make the block.
https://www.instagram.com/p/CFvCAgpnurd/
Barely tap the gas, and the rears light up. This thing is an animal.
Oh, and disregard the stalling. The clutch is..... "fun".
09-29-2020, 05:57 PM
#5
Ok i need this. Damn that sounds good
09-29-2020, 07:54 PM
#6
Dude, that Maserati .... I'm no fan of italian engineering, but MAN they make a good sounding intake/exhaust note. \m/
Well, I guess you just made me more confident in my trans.
LOVE the car man!!!
'98 PP13B powered "RX986"
10-06-2020, 12:45 AM
#7
Decided the radiator mounted on the cage wasn't getting good enough airflow, so it's been relocated. Also tied the OEM radiators into it, so the coolant now goes back through the big one, then all the way forward into the two OEM radiators, then back to the engine. Installed a small booster pump to make sure it flows all the way. Pretty sure it won't overheat as quickly now.
10-15-2020, 06:50 PM
#8
Ever seen 315x17 tires on a 986?
Fat as hell. Some fender flares are in order, I think.
Also, put some mufflers on. The open exhaust was glorious, but the sheer volume was just way too much to be driving around on the road. Two 3" Borla Pro XS solved that issue. Looks a bit goofy, but I love it. Because racecar.
Oh, and I nearly forgot to mention; the new radiator setup works, and she's running nice and cool.
10-17-2020, 11:13 AM
#9
What a blast this will be!
Which tires are those and do you know the 17x9 wheel weight?
10-16-2020, 11:48 PM
#10
No real updates at the moment, I just love this shot. This is the garage that 100% of the work on this car was done, except the alignment, weighing, and roll cage.
I'm not ashamed of how much of the contents of that garage came from Harbor Freight.
Car going to the dyno Monday morning, I'll be able to give you some real numbers after that. Hopefully getting precision weighed soon after that, so we can see what the final weight is, as well if we've totally boned our weight distribution or not.
10-17-2020, 07:04 PM
#11
The tires are 315/35-17 Toyo Tires Extensa HPII, which is damn near the only street tire I could find that would fit those wheels. At $140 each, not too hard on the wallet, either. You can see they're a bit bulged, but the only 295x17 I could find was the Hoosier A7 and R7 racing slicks. She's not quite ready for that yet.
As far as weight, no. We were too excited to get them on to remember to stop and weigh anything.
2001 Porsche Boxster with a Maserati V8.
Instagram: @squonkwerkzgarage
10-17-2020, 07:28 PM
#12
You already booked time at a track??
10-17-2020, 07:52 PM
#13
Haha, oohhh no. A proper track shakedown is still a few months out. (Mainly due to the fact I'm on an extended work trip right now.)
Monday morning is dyno day!
10-18-2020, 06:55 PM
#14
I look forward to the dyno day. You are my transmission "canary". LOL
Your numbers come back and then I will know how much NOS I can run
10-18-2020, 07:16 PM
#15
Indeed! I most definitely feel like I'm doing some good testing. It seems like the people that may or may not have tested how much power the 5 speed can handle haven't documented it very well, which I intend to recify.
Eventually, I might even make a seperate thread about the 5 speed and associated data for it, seeing as after the extensive research I have done and have turned up an amount of information equivilant to the square root of jack ****************.
10-19-2020, 12:42 AM
#16
I’m not sure I’d put money on it but I think we’ll all be surprised. You’re a good test too, lots of power, lots of tire and you there’s nothing harder on a transmission than an autocross (no rolling start, and all low gear fast shifts). I think if it’ll survive an autocross it’ll survive the track (maybe heat would come into play on the track but a cooler would solve that).
2003 911 C2
10-19-2020, 04:50 AM
#17
From what I've seen with the local spec boxster crowd. Heat and bad shifting kills the five speed. Some guy tap the case so cool oil from the cooler pours directly onto third and fourth gears because those are the gears that they kill the most. A cooler can't hurt but I know some guys who don't run a cooler at all and their transmission's last for two-three seasons. They swear it's all about correct shifting. I have one friend who got bored racing spec and put a 3.4 in his car. He tracks it constantly and I believe he's still using a 5 speed with no problems. That's around 300hp. The porsche 3.4 has a lot less torque than the V8 you're using though. I think you'll be fine as long as you don't try dropping the clutch in first
Woody
10-19-2020, 07:57 AM
#18
We'll definitely be taking it easy on the standing starts, that's for sure.
Probably won't be taking it to autocrosses very often at all anymore. We're kind of leaning towards doing some SCCA Time Attack events with it, that's just about the only place left it'll fit in.
Car's getting dyno'd here in just a few, so we'll have some hp/tq numbers to chew on!
10-19-2020, 10:49 AM
#19
Great build... because racecar!!
10-19-2020, 11:48 AM
#20
ONWARDS, TO GLORY!
| Thread Tools |
| Display Modes |
Hybrid Mode
