Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 05-30-2018, 03:00 PM   #1
The Radium King's Avatar
Originally Posted by truegearhead View Post
Here's what I'm thinking, the Rough Mustang vents are flexible, effective and cheap. Apparently the best position is at the top of the wheel well where air pressure is the highest (the tire pulls air up the back as it spins and the incoming from the ducts and rad meets it at the top of the tire.
problem is that the top of our fenders is curved, so tough to find anything that would match that curve properly. that's why i like the first pic i posted - just several slashes across the fender, then bend them down.
Old 05-30-2018, 10:38 PM   #2
Cunningr's Avatar
Yeah I gave a better look at the pic, that would be the way to go true cut into vender luvers, like the old hot rod uses. That would flow, and old school hotrod fabricator should be able to do that. Isnt there an inner fender well would need some kind of venting as well to connect the 2 points to actually get the heat out?
Old 05-31-2018, 03:49 AM   #3
truegearhead's Avatar
Ya I agree, the problem is not skilled enough to cut and bend the fenders and make it look right without rewraping or repainting both fenders. I’m thinking the aluminum or ABS panels would take the fender shape with a enough rivets
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
