Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 05-06-2018, 10:25 PM   #1
AZ986S's Avatar
Exhaust noise reduction for HPDE
Hey all,
Now that I have the NHP headers with straight mid pipes and Borla S-Type mufflers, it is obviously louder. I'm heading out to AMP for the last DE of the season and they have a sound limit of 96 dB I believe. I'm hoping that I'm not over that limit, but just in case, I'd like to be prepared. This Borla exhaust is a dual oval tip, and non removable. Is there a solution to redirect the tip downwards on these?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 05-07-2018, 05:27 AM   #2
a number of exhaust mfgs make turn down tips. Search the usual suspects like AWE, Fabspeed, TPC, GMG, Sharkwerks, Borla, etc. Or just have a local welder or exhaust shop make one up for you quickly.
The typical 95 db limit is a lot louder than you think it might be so you could be w/in spec... download an app from the googelplay or iTunes store to test first.
Good luck
"Cool Prius!"
- Nobody
Old 05-07-2018, 05:37 AM   #3
husker boxster's Avatar
When I drove at LS in '14, they had a 92 dB limit. To get around it, guys had pipes that pointed to the left side of the car (the sound police were on the outside of T5, which was on the passenger side). You might want to fab a fart can extension that can be attached to point the sound the other direction.
I have my PSE permanently on. I got the black w/ red meatball flag in the 2nd session. Sound police got me at 94 dB. Obviously I couldn't fab a fart can (nor did I want to), so I short shifted by the sound police booth after that. My guess is you'll be over the limit if a stock PSE is 94.
1989 928 S4 5 spd - black
Old 05-07-2018, 07:59 AM   #4
Racer Boy
Racer Boy's Avatar
Easy solution! Find out where the sound guy is, then short shift or lift when you go by him.
Old 05-07-2018, 09:31 PM   #5
Search on "laguna exhaust", laguna seca exhaust, etc (which are all shorthand for the exhaust setups used at Laguna Seca Raceway where the sound is also limited) and you'll find a plethora of ideas...
Google image search=laguna+exhaust
Something like this can be quickly put together with materials from Home Depot.
Will it help enough to pass 96db? YMMV.
In my experience at Laguna Seca, you might have a chance at making 96db by focusing the sound to the drivers side (and maybe add a bolt on fart can silencer) but the only way to make 92db is to use a stock Boxster muffler.
Old 05-07-2018, 10:38 PM   #6
AZ986S's Avatar
I think this one should work
Old 05-08-2018, 07:38 AM   #7
rastta's Avatar
I have two ways of reducing sound on my Boxster. One is a set of supertrapps that bolt on the exhaust and the other is a set of "Laguna pipes" that I built which are essentially angled pipes with a small insert and exhaust packing stuffed in them. The pipes didn't work well enough to pass sound - 92dB was the limit and I was hitting 94-95 dB. The supertrapps were more effective but I still have to lift when going by the sound station. My car without either is at about 98dB wide open.
Pipes installed - 3" diameter
Inside
Inside #2
Supertrapps
rastta is offline   Reply With Quote
Old 05-08-2018, 09:54 PM   #8
Track rat
Topless's Avatar
I just always run stock exhaust when running under sound restrictions. Bolt it on and you have a sure thing, vs whack and hope, and maybe go home after 1 session.
Old 05-08-2018, 11:24 PM   #9
Inside
Inside #2
Supertrapps
That looks sweet with the Supertrapps sticking out like that!
Old 05-11-2018, 07:20 PM   #10
AZ986S's Avatar
I know this is not for the purists
Here's my fist low budget / in a hurry attempt at turn down tips.
I used 45 degree 1 1/2 in ID galvanized exhaust piping elbows, wedged inside the ID of the round pipe in the Borla muffler. Then I used exhaust patching sheet aluminum (malleable) and fabricated 5in wide by 12 in long pieces that wrap around the oval Borla tip and then around the 1 1/2 in elbow pipe. Then I used hose clamps to attach to both. As you tighten the pipe clamp, it draws in the sheet metal and does a good job at holding the pipe in place. It is not moving. I hope it works well enough for 96 dB. We shall see!
Old 05-12-2018, 10:51 AM   #11
Racer Boy
Racer Boy's Avatar
Nice! What ever works, right?
Old 05-12-2018, 01:48 PM   #12
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
