I know this is not for the purists
Here's my fist low budget / in a hurry attempt at turn down tips.
I used 45 degree 1 1/2 in ID galvanized exhaust piping elbows, wedged inside the ID of the round pipe in the Borla muffler. Then I used exhaust patching sheet aluminum (malleable) and fabricated 5in wide by 12 in long pieces that wrap around the oval Borla tip and then around the 1 1/2 in elbow pipe. Then I used hose clamps to attach to both. As you tighten the pipe clamp, it draws in the sheet metal and does a good job at holding the pipe in place. It is not moving. I hope it works well enough for 96 dB. We shall see!
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
