Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 04-28-2018, 05:11 PM   #21
Porsche "Purist"
Paul's Avatar
Originally Posted by jsceash View Post
Had you changed any of the motor mounts to solid or semi solid. It was one of the side effect I had at track when I changed to Wevo's
How did you resolve this issue?
1987 924S. 2002 996TT. PST-2
Old 04-29-2018, 04:56 AM   #22
Not had a chance to work on it yet. Wife had bilateral hip replacements Friday and have spent most of my time at the hospital.
Deadeye is offline   Reply With Quote
Old 04-29-2018, 02:04 PM   #23
Porsche "Purist"
Paul's Avatar
Hope the recovery is quick, but I suspect not only your car but also your wife will be in limp mode for 4 to 6 weeks.
Old 04-29-2018, 03:40 PM   #24
Ba dump bump. Well said, but so far so good. Thx
Old 05-21-2018, 04:49 AM   #25
Update. I replaced the throttle body and changed out the pedal potentiometer with one from a parts car. Will have a chance to test on track this Saturday.
Old 05-22-2018, 06:01 PM   #26
Porsche "Purist"
Paul's Avatar
Did you do the relearning procedure?
Basically without touching the gas pedal, turn the ignition to run (do not start) and listen for the throttle motor to run. (about a minute or less) Then turn the ignition off for at least 30 seconds then back on.
Old 05-29-2018, 03:53 PM   #27
Problem did not re appear at the track Saturday. 4 sessions and it ran to checker on all 4. Not sure which component was bad, the pedal potentiometer or the throttle body, but it's cured
Old 08-15-2018, 07:08 PM   #28
Porsche "Purist"
Paul's Avatar
Still cured?
Old 08-16-2018, 04:19 AM   #29
Originally Posted by Paul View Post
Still cured?
So far so good. Three days at the glen last WE and no problems.
