02-23-2018, 09:58 PM
oil pressure gauge install DONE!
Parts are gathering, now in the planning stage. The functional wiring of the gauge is pretty simple obviously, short of getting the wire ran from the sender up. Not worried about that. The question is, did any of you run a switched hot for the gauge light? Did you pull it from any particular wire? With all the immobilizer stuff, and being somewhat worried about tapping into the wrong wire for some reason, just wondered what you guys did. Seems like a real B!tch to get to the wiring cluster! Thanks!
02-23-2018, 10:21 PM
there's a spare connector in behind the lower cubbies for a cell phone - you can get switched power off of it.
02-23-2018, 10:27 PM
Mine has the climate controls in the lower portion just above the batwing. The cubby block is just above. Is it difficult to find or is it pretty obvious? I thought about running a wire across from the fuse cluster so that it is switched on with the actual headlights...
02-24-2018, 05:14 AM
Alternately, you can tap into the light for the console ashtray, which is what I did.
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
02-24-2018, 07:08 AM
I ran a wire along the underside of the dash using a fusetap from the fuse panel.
Can't remember what fuse but I think it was A9 or C7.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
02-24-2018, 08:31 AM
Oh, that might just be the ticket! Forgot about that little light. I don't particularly care if it dims or not. Still not sure where I am going to put this thing. Not a single flat surface anywhere in the dash... and I'm not yet ready to give up my center cubby. It is probably going to wind up under somewhere.
Also, what do you guys think of this oil temp setup, running it off the bung on the other side? Think the sender might be too deep?
Oil Temperature Gauge & Sensor Set - Engine - Transmission - 1/8-27 NPTF By Patrick Motorsports Porsche & Mid Engine Performance Specialists
02-24-2018, 08:36 AM
02-24-2018, 08:41 AM
Originally Posted by steved0x
Cool! Much, much better!
03-16-2018, 04:25 PM
Installed!
Got the oil pressure gauge installed today. Went with a 996 sender and VDO gauge. The mount is from Autometer. Location actually works quite well. Hot oil pressure at idle sits just above 1 bar.
Overall, not a bad job, but a little fiddly here and there. Ran the sender wire down through the shift cable boot and up through the center console. Pulled hot and ground from the extra acc lead behind console. Pulled light from the center console light. Most of the time spent was wiring and getting everything to look tight.
03-16-2018, 04:30 PM
Looks good! I'm too tall, I think my leg would hit it...
03-16-2018, 06:40 PM
Artist, 986S tinkerer
I never did the light since I don’t track at night. If I’m driving on the highway at night I don’t really worry about oil temp and pressure.
03-16-2018, 08:15 PM
Believe me, I almost didn’t do it. But everything was apart and I was there... so went ahead and did it.
04-02-2018, 05:06 AM
I just did this also and wanted them up on top of the dash for easy vision while tracking. Used a mustang gauge pod, lightly modified. Pretty pleased with the result
04-02-2018, 07:46 AM
Nice! Did you have to take the dash out to get them to mount up/run wires?
04-02-2018, 09:23 AM
1998 Boxster Silver/Red
I'm most impressed with how he did the job hovering at a 90 degree angle? A DYI would be awesome!
1998 Porsche Boxster
04-02-2018, 10:11 AM
my anti gravity skills are legendary.
In actuality, if you've ever done any car wiring work, this is straightforward.
If you remove the cover of your sun sensor front and center of the dash, you'll see a hole for the wiring harness.
Remove your radio and hvac system, get your hand back there, and start feeding the wire up from behind the lower console.
Then starting from the top of the dash, drop a feed wire down until you see it by the center hvac vent. tape your sender wires to that feed wire and pull it back out of the dash.
From there you can do the same for power and grounds. Then just wire up.
I attached to dash with heavy duty velcro and a few spots of butyl just to keep it from vibrating.
04-03-2018, 07:50 AM
Nice job. Did you find that it impedes your vision/ distraction at all on the track?
04-03-2018, 09:25 AM
04-03-2018, 10:40 AM
My first track day with this setup is tomorrow, so I'll let you know. I moved it towards me on the dash (which slopes downwards) to improve visibility and went with black gauges to reduce distraction. I believe they will be more at-a-glance then a distraction, but will follow up after some time at lime rock.
04-06-2018, 03:10 AM
So gauges were not a distraction at all and line of sight was fine. It was cold out so oil temp only got to 235. Pressure seemed consistently low, but the gauge seems to move kinda slow so it was hard to tell. Any other vdo guys have this issue?
