Originally Posted by The Radium King
there's a spare connector in behind the lower cubbies for a cell phone - you can get switched power off of it.
Mine has the climate controls in the lower portion just above the batwing. The cubby block is just above. Is it difficult to find or is it pretty obvious? I thought about running a wire across from the fuse cluster so that it is switched on with the actual headlights...
