Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 02-07-2018, 04:23 AM   #1
truegearhead's Avatar
Camber w/out GT3 Arms, avoiding the penalty
I'm trying to fit my car into NASA's TT5 class and there is a heavy penalty for non-stock control arms. Currently I have Elephant racing GT3 arms but I'm curious if anyone has tried to get acceptable front camber on a lowered car with notched strut mounts or camber plates. If I can do this I'll go back to stock.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 02-07-2018, 05:34 AM   #2
depends what you consider acceptable. I'm anticipating 2.5 degrees with slotted shock towers, lowered suspension, and factory coffin arms. camber plates should get you that or more
Old 02-07-2018, 07:54 AM   #3
rastta's Avatar
I have 3.1 degrees in front with no GT3 arms - just slots and lowered suspension. It's really low though and adjustability is limited. I'm honestly going to the Elephant arms when I tear it apart for the shock rebuild/maintenance. You like those arms?
rastta is offline   Reply With Quote
Old 02-07-2018, 08:09 AM   #4
seningen's Avatar
re-drill the upper mounts on my S and I get -2.5 with stock arms, I do have lowered springs and K-Sports.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is online now   Reply With Quote
Old 02-07-2018, 08:34 AM   #5
That’s good to hear! I love the elephant arms, the replaceable ball joints are a huge plus. They can be replaced in minutes without a press, there’s just a snap ring that releases them. It’s also nice to be able to adjust camberwithout shims (like the true Gt3 arms).
2003 911 C2
Old 02-07-2018, 09:56 AM   #6
The Radium King's Avatar
i've heard that the elephant control arms attract rats so you don't want to keep them in your garage for any length of time; better sell them to me cheap as soon as you remove them ...
Old 02-07-2018, 12:09 PM   #7
AZ986S's Avatar
Wow!
Seems like slotting or redrilling and you can get -3.1 degrees camber in the front?
My experience is -1.8 deg in the front with H&R lowerings springs with stock struts, mounts AND slotted towers. Looking at the upper mount fit, there is NO room for more inboard movement even if I were to slot more. The mount will just contact the tower, so what do you do then? Machine the upper mount? Maybe camber plates have smaller outer dimensions and allow more inboard strut movement. Never tried.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
