Old 11-27-2017, 01:34 PM   #41
steved0x's Avatar
Originally Posted by Quadcammer View Post
What are people doing for front track arms? Seems the only option is porsche @ $350+ each
The 997 rear track arm is the same as the 996 all four corners track arm and the 986 Boxster front track arm, you can get it as a TRW or Meyle part for way cheaper than the Porsche branded part and much better than the various off brand parts that show up from time to time, part # 99733104301, on the Meyle website they make this and show it as a cross for 99634104306 and a couple of other part numbers (earlier revisions maybe?)
I am running these on my car now in the front, ordered Meyle brand from FCP Euro and they sent TRW by mistake which was OK with me so I kept them and installed them. They are an exact match.
Old 11-29-2017, 11:33 AM   #42
dammit, wish I would have seen this sooner. Got a very low mile used set on ebay for cheap, but would have preferred new. Oh well.
This place Topspeed Pro1 sells steel versions of this with what look like heim joints, but i didn't really trust it.
Old 11-29-2017, 04:41 PM   #43
911monty's Avatar
What is going on with TRW? Are they getting out of aftermarket or is Porsche cracking down? I cannot find TRW anywhere. Sites that show them don't stock them and when called find they are NLA. Lower control arms have ben unavailable forever and now uppers also gone????
Old 11-30-2017, 05:05 AM   #44
edc
550 Anniversary
edc's Avatar
There was some sort of dispute with Porsche so for the past 4 years or so it has been increasingly hard to find the aftermarket TRW version with the Porsche logo ground off.
Old 11-30-2017, 05:59 AM   #45
steved0x's Avatar
Dang that sux as TRW makes good stuff (I guess including the original Porsche stuff )
Old 11-30-2017, 08:51 AM   #46
911monty's Avatar
Did a little research. ZF Friedrichshafen purchased TRW in May 2015. Apparently selling cheap aftermarket in direct competition with their own expensive Porsche parts does not fit ZF's marketing strategy in their quest for world domination. Bummer.
Old 11-30-2017, 10:12 AM   #47
steved0x's Avatar
Maybe Meyle will step up and start making the rear track arm, they already make the front ones, coffin arms, rear toe arms, front tie rod ends, and drop links now. (Also brake rotors, some brake pads, and even an HD water pump now...)
Old 02-27-2018, 02:57 PM   #48
Ok all done. Need to get alignment done but it looks good
Old 02-27-2018, 06:04 PM   #49
steved0x's Avatar
Looking good and you have probably said it on other threads, what front bumper lip is that?
Old 02-28-2018, 05:26 AM   #50
its actually a universal front lip from All-fit automotive. Its kinda cheesy in person but i'm trying it out.
Old 03-01-2018, 12:07 PM   #51
steved0x's Avatar
Let us know how it goes, looks good to me and if it helps when driving, even better!
Old 03-05-2018, 12:47 PM   #52
so to sum up, I was only able to get to -2 degrees even with a lot of slotting in the shock tower.
so..well, thats unfortunate, but so be it. At some point I'll upgrade to some gt3 style LCAs, but I'm gonna run it and see how it feels and how my tires wear.
Old 03-05-2018, 01:36 PM   #53
steved0x's Avatar
Are the top mount pins up against the edges of your expanded slots or is the nose of the top mount contacting the body structure? If the nose of the top mount is contacting, you could probably cut or grind off some of that nose and give yourself some more room and squeeze a little more neg camber, maybe another 5mm worth?
Old 03-05-2018, 02:43 PM   #54
rastta's Avatar
You can also throw top camber plates on that add 1 degree. That will get you 3.
rastta is offline   Reply With Quote
Old 03-05-2018, 05:27 PM   #55
AZ986S's Avatar
That's going to be my next project. I might wait until I have to replace the front struts, but that may take a while I had the same issue, the strut mount body hits the inside of the sheet metal strut housing. I took a look in there and there is not much metal to grind away and it could weaken the mount.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 03-05-2018, 05:46 PM   #56
steved0x's Avatar
You are right, I thought there was more to grind, my bad. That picture shows it pretty clearly.
Old 03-06-2018, 03:43 AM   #57
truegearhead's Avatar
I’m running the Megan racing 987 rear toe links on my 986. They work, no idea why they don’t advertise them working on 986’s.
2003 911 C2
NASA HPDE Instructor
Old 03-06-2018, 05:11 AM   #58
Yup, I got them on as well. Heavy as hell, but they fit and work fine.
Old 03-06-2018, 06:45 AM   #59
rastta's Avatar
Yeah, I wouldn't mess with the top mount. I'm having Ohlins R+T coilovers installed in my Cayman. I debated about putting camber mounts in - but since it's a street car I went with the stock mounts.
Old 03-06-2018, 06:59 AM   #60
rastta, how were you able to get to -3 without lcas?
