Old 04-10-2017, 04:50 PM   #1
PGas32's Avatar
Wiper wiring
One of the last things I need to finish up for my SPB is wiring up the wipers so they operate at a single speed off of a dash-mounted switch...or maybe even variable speed with a knob. Either way, can someone explain in very simple terms what exactly needs to be done? I have the wiring diagram, but basically everything I know about electrical stuff has been learned throughout this build project and I'm not quite at the point of building my own circuits yet.
2002 Boxster S
2001 911 race car
Gone:
Spec Boxster #714, 2006 Cayman S, 2006 911 S, 2016 Cayenne GTS
PGas32 is offline   Reply With Quote
Old 04-11-2017, 06:05 AM   #2
rastta's Avatar
All I know is that I have two relays on my car that I had to replace. They go to a knob on the dash that has three positions. I didn't trace the wires back to the switch though.
rastta is offline   Reply With Quote
Old 04-11-2017, 08:12 AM   #3
My notes from installing my custom switch panel in the SPB show wire #49 being the key wire. In the wiper stalk connector there are 3 connectors you replace. One comes from #49 and the other two go back (switched) to the wiper motor. There are 3 terminals/wires on the wiper motor (and ground). Let's call them T1, T2, T3. (I don't recall how they are actually labeled or colored. Bentley manual shows it.) T1 is directly wired to #49. If T2 is connected to #49, wipers go slow. If T3 is connected to #49, wipers go fast. So, I put a DPDT on-off-on switch there. Middle is off, up is fast (49-T3), down is slow (49-T2). You could just use a single pole switch if you only want fast on.
trygve is offline   Reply With Quote
Old 04-12-2017, 06:45 AM   #4
PGas32's Avatar
Awesome, that should be enough to get me on my way. I really like that panel setup, by the way! Is that a carbon wrap of some sort? Or the real deal??
2002 Boxster S
2001 911 race car
Gone:
Old 04-12-2017, 07:18 AM   #5
It's not carbon fiber. I found a local guy who does "water transfer printing" / "hydrographics". Faux carbon is one of many patterns possible. Leopard print or camouflage didn't seem racy enough. They also did the rest of the panel surround, and both engine covers. It looks great and adds 10 hp.
Old 04-12-2017, 12:21 PM   #6
RedTele58's Avatar
Trygve - that looks great!
Old 04-15-2017, 09:16 AM   #7
Thanks! It was not expensive. Big improvement when the engine covers look a little bit beat-up.
Old 04-15-2017, 05:46 PM   #8
Trygve, looks fantastic! Gotta be worth 2 sec's per lap.
