Old 08-16-2016, 09:53 AM   #1
Recommended track day tire size?
I'm looking for tires for my dedicated track day Boxster. They need to be street-legal. I'm using 17" boxster s rims and will go for 255 rears. What would you go for up front? 235? Will I be able to run 235 on a staggered set of boxster s rims?
1990 944 Turbo
2007 Renault Clio RS 197 (Sold)
1998 Boxster 2.5L Track Day/ Race Car
2011 Mistubishi i-MiEV
Norway
Bebbetufs is offline   Reply With Quote
Old 08-16-2016, 09:59 AM   #2
steved0x's Avatar
I think the spec boxster guys run 235/40/17 up front on the stock 7x17 wheels, and 255/40/17 on the stock 8.5x17 wheels. I like to run 225/45/17 on the front OEM wheels and 255/40/17 on the stock back sizes.
For tires, I am like a broken record, I like the hankook R-S3, 200 TW tire, good on track and lasts a long time. I have a trailer and sometimes drive my street tires to/from the track but I have got lazy and now bring them as spares and leave them on the trailer and drive on the R-S3 all the time
If this is a dedicated track only Boxster, and is only driven to/from the track, there are lots of good 200 TW tires, Bridgestone RE-71R, BFGoodrich Rival-S, Advan, etc. Then there are some street legal 100TW tires like Toyo R888 and Nitto NT-01.
What all can you get in Norway?
Old 08-16-2016, 10:19 AM   #3
I can get most makes if I order in advance, but since I'm hoping to get them by Saturday my options will be limited by what is in stock. I was thinking more in terms of 100TW tires, but this may be too much for the street? It rains a lot over here, and I need to cross mountains on the 8h drive to and from the track.
I'm running PSS9s with SPEC racing springs. I have -2.5 camber front and -2. rear.
I ran AD08Rs on the Clio RS and liked them. I have not tried anything more track focussed. My mates are running Federal 595RS-R but they complain about what wet grip. The AD08Rs are good on a wet road, but may be a little tame on track.
I need to be able to use the tires also on a wet track. Are the 100TW tires capable of building heat and sticking on a wet track?
1990 944 Turbo
Norway
Old 08-16-2016, 11:41 AM   #4
steved0x's Avatar
I don't have experience on that, I am new to the 100TW tires. I have a set of Toyo R888 that came with my trailer but I have only run them in the dry, and they are pretty worn down anyway.
Old 08-16-2016, 12:09 PM   #5
In my experience, I'd say that the Toyo RA-1 is probably the best all-around tire for both wet and dry track racing. This tire is good in the rain but will likely be a little slower in the dry than a Toyo R888 or NT-01.
Old 08-16-2016, 12:24 PM   #6
That is valuable information. Thank you.
1990 944 Turbo
Norway
Old 08-16-2016, 08:19 PM   #7
One more thing - be a little careful on a brand new set of RA-1's with full tread depth in the dry; they can feel loose until they scrub in and get some wear on them.
Old 08-17-2016, 05:27 AM   #8
I ended up with a set of Federal 595rs-rr in 225 and 255. I'm hoping I've made a good choice, but I had to go with what was available and within my budget.
1990 944 Turbo
Norway
Old 08-17-2016, 07:03 PM   #9
JayG's Avatar
You also probably can not put 235 wide tires on a 7" wheel, you need at min 7.5". 225's fit a 7" fine
YMMV
Old 08-17-2016, 09:11 PM   #10
YMMV
Actually, the 235's will fit fine on the 7x17 wheel. That is what Boxster Spec runs for the fronts in the staggered setup.
Old 08-18-2016, 07:42 PM   #11
Topless's Avatar
This is good advice. I would add the RE-71r to your short list of street capable track tires. It is rated as 200 TW but grips like 100 TW. It is better in the rain than all other 100TW tires as well.
Old 08-18-2016, 07:56 PM   #12
JayG's Avatar
I wonder if that is true with RE-71's. In looking at the spec, the min for them in 235 is 7.5" and I just ordered new ones in 225 for my 17x7 wheels.
Could Tire Rack be wrong
Old 08-18-2016, 08:02 PM   #13
Topless's Avatar
It's a stretch Jay but they will fit. The result of running 235s is a little more contact patch and a little less sidewall control. I have run both and usually prefer a 225 on a 7" wheel.
YMMV
Old 08-18-2016, 08:21 PM   #14
JayG's Avatar
YMMV
I wonder which would be better with my stock suspension
Old 08-18-2016, 09:55 PM   #15
At the OP.....can out get Nankang NS2R in Norway. Readily available in Europe.
They do 180, 120 and 180tw. I have the 180 'street' compound and are fine on the road
jimk04 is offline   Reply With Quote
Old 08-19-2016, 05:58 AM   #16
Topless's Avatar
My preference would be 225. I expect exaggerated rollover with limited camber.
Old 08-24-2016, 11:48 AM   #17
Gary R.'s Avatar
All I know run a square setup of 8.5x17 all around with Toyo RR's. For the street and track I would go with full tread 255/40 Toyo RA-1's...
Gary R. is offline   Reply With Quote
Old 08-25-2016, 01:09 AM   #18
I ended up getting a set of Federal 595rs-rr. So far I'm pleasantly surprised, especially in the wet on the street. When new you can definitely lean on them as long as there is not too much standing water.
I would not put 235s on a 7J rim. The 225s I have now are already wide for the rim. I have a bit of experimenting to do With tyre pressures before I can say anything definitive about the grip though. After some initial trial and error I cut 2 Seconds off my previous best of 1.50. howevwe, I'm still not consistent enough to be able to tell what is Down to the tyres and what is me improving.
1990 944 Turbo
Norway
Old 08-25-2016, 12:18 PM   #19
Yes, indeed, the Toyo specs for the RR 235/40ZR17 say a minimum of 8.0" wide and 8.5 preferred.
Nevertheless, this is the spec size for the 17x7 front rim in Spec Boxster, and it seemed to work fine. Toyo doesn't make a narrower tire for 17" rims.
Of course, now most people have moved to the square setup--255/40-17 on 17x8.5 all around, which does meet Toyo's requirements.
Greg Holmberg is offline   Reply With Quote
Old 12-03-2018, 09:31 PM   #20
For Autocross, I'm debating 17" or 18" Rims with RE-71R (225/255 and 225 or 235/265) respectively. I've got rims for either.
WindS is offline   Reply With Quote
