Old 05-03-2016, 03:03 PM   #1
Cage tied in to the a-pillars. Risk of cracked windshield?
I'm buying a custom cage and would like it to be connected to the A-pillars. Will this cause the windscreen to crack?
1990 944 Turbo
2007 Renault Clio RS 197 (Sold)
1998 Boxster 2.5L Track Day/ Race Car
2011 Mistubishi i-MiEV
Norway
Bebbetufs is offline   Reply With Quote
Old 05-03-2016, 06:39 PM   #2
Racer Boy
Racer Boy's Avatar
I've had two cars with the cage tied into the A-pillars and never had the windshield crack.
Old 05-03-2016, 06:51 PM   #3
78F350's Avatar
Not that is answer's your question, but have you read through the first part of Tom's build thread? Spec Boxster Build
Some good pics and info on the roll cage in the first two pages.
Old 05-03-2016, 10:09 PM   #4
Thanks guys. I'll read through it and see what I can learn. The cage is custom, but for a group buy, so my options are limited. I'll have to find ways to adapt things to reach my goals.
Old 05-04-2016, 11:58 AM   #5
Do you have to remove the windshield to weld the cage in?
1990 944 Turbo
Norway
Old 05-04-2016, 01:01 PM   #6
Racer Boy
Racer Boy's Avatar
The race cars in question (Datsun 1200 and RX7) didn't. The fabricator it th cage in, then cut a piece of steel plate to bridge the gap between the cage and windshield frame. He then placed the plate into place, and was able to tig weld it in. He was an excellent fabricator, so the gap was pretty small.
Old 05-05-2016, 11:49 AM   #7
Thanks for the useful information.
Unfortunately it seems the cage I wanted has a flaw in that it is too low on the passenger side for me to sit in the passenger seat and let others have a go. I'm looking at options. This was a nice ChromeMoly cage which is very light.
Does anyone know the average weight of a good multi-point cage for a Boxtster?
1990 944 Turbo
Norway
Old 05-06-2016, 08:18 AM   #8
rastta's Avatar
Mine is tied in at two places - welded directly near the top on the side and with a plate lower on the side. I run a Poly windshield.
rastta is offline   Reply With Quote
Old 05-06-2016, 10:47 AM   #9
Approximately 1.6 lbs/ft for 4130 chromoly tubing with 1.75" outside diameter/0.95 wall thickness. Photos are in the Spec Boxster Build link above.
A rough estimate of my cage is >50 ft (which was designed for safety, safety, and safety as the top three priorities) which would be a min weight of 80lbs.
I am sure that a cage can be built lighter (smaller diameter tubes, thinner wall thickness, and a simpler design using less material) ... but do you really want to skimp on the cage?
Old 05-06-2016, 11:27 AM   #10
Thanks.
The one I'm looking at is 46kg. which is about 100lbs. I consider it heavy.
Also, I will have to learn to weld better and install it myself, or perhaps I could tack it in place and have a pro come in and weld it in a couple of stages.
1990 944 Turbo
Norway
