Old 11-17-2015, 05:03 AM   #1
SpecBox
Spec Boxster build @ ATLspeedwerks
Just picked up a Boxster donor (no key) and looking forward to getting into some PCA racing. Spec classes are great - I spend a lot of time in the Spec Miata crowd. Hoping to see the class continue to grow. We'll do our part here in the SE.
Some pics from yesterday, pulling apart the interior but leaving everything else intact until this afternoon when I get the key from Porsche and get it programmed into the immobilizer:
toddlamb is offline   Reply With Quote
Old 11-18-2015, 03:44 AM   #2
SpecBox
Spec Boxster: More teardown and we got the key programmed at Porsche to finally be able to start the car. Engine fired immediately and runs well. Transmission seems good too. It appears we have a solid donor!
Old 11-18-2015, 05:53 AM   #3
RedTele58's Avatar
Cool!
Keep the pictures and information coming!
Old 11-24-2015, 04:02 PM   #4
Keep us updated!
Old 11-25-2015, 03:55 AM   #5
spacearchitects's Avatar
subscribed. looking forward to updates
_____________________
1997 Spec Boxster #61
2001 GT3 SuperCup #67
1967 230SL
www.spacearchitects.com
spacearchitects is offline   Reply With Quote
Old 01-27-2016, 10:17 AM   #6
SpecBox
UPDATE
We've been extremely busy with the Spec Miata side of the business. Just got back from Sebring where we did live streaming in-car. It wasn't ideal but it's a start. You can see the replay from both races here (sat race 3rd/65, sun race 2nd/65):
Toddspeed on USTREAM: .
For SPB, we actually have 3 donors in-house right now, and we decided to build up a black car instead of the white one we stripped, as we have a customer interested in a white car after ours is done. We obtained a factory hard top and a couple of fiberglass hard tops for fitment. Right now we're in the process of designing our own cage, as we have a lot of experience doing cages for other cars and feel like we can build a better mousetrap.
So having said that, sadly we've had to back out of Sebring and expect to get the SPB done for PCA at our home track of Road Atlanta.
Here's a few pics as the floor plates are installed and the cage is tacked into place.
Todd Lamb
Atlanta Speedwerks
Old 01-27-2016, 11:26 AM   #7
I would suggest use of the aftermarket fiberglass top. The factory hard top weights a lot and puts the weight in the wrong place (up high).
What type/size tubing are being used for the roll cage?
Old 01-27-2016, 12:38 PM   #8
SpecBox
Yes we plan to use the fiberglass top, but we are designing the cage to be used for either top. Although I've heard once the factory top is prepped it's actually the same or lighter than the fiberglass top when you include the window/hardware.
1-1/2" .095 for the majority of the cage. We're waffling on what exactly to do since SCCA would theoretically require 1-3/4" in T4 (we are working on getting the SPB classed in T4 for Majors). And also for PCA the car weight is right at the limit for bigger tubing, but we were unable to get any definitive answer from the PCA tech gurus.
Todd Lamb
Atlanta Speedwerks
Old 01-27-2016, 04:38 PM   #9
I personally chose 1.75 x 0.095 DOM MIG-welded for my Spec Boxster after consulting with Josh Lucas of Lucas Fab in Huntington Beach, who built my cage.
A spec Boxster with driver minimum weight is 2650 lbs. I weigh 180, so car minimum is 2470 lbs without driver.
PCA says for a car without driver, under 2500 lbs. requires 1.50 x 0.095 in mild steel. Given that the Boxster is only 30 lbs under that, I think it's prudent to step up to the next level. For over 2500 lbs, the PCA says 1.75 x 0.095 or 1.50 x 0.120 in mild steel.
NASA has exactly the same rules for mild steel. They're different from the PCA for 4130, but my builder does not recommend 4130 because it's more brittle (gives suddenly), even though it's stronger in the same sizes.
The SCCA says for a car of "GCR Vehicle Weight" (with driver, I think), under 2700 lbs, 1.5 x 0.095 or 1.625 x 0.080 mild steel is required. Again, since a Spec Boxster is only 50 lbs under this, I would go up to the next level, which for the SCCA is 1.50 x 0.120 or 1.75 x 0.095 or 2.0 x 0.080.
So, in summary, with all three organizations, you can technically get away with 1.5 x 0.095 mild steel, but I think 1.50 x 0.120 or 1.75 x 0.095 would be smart, since the Boxster is right on the edge of the limits.
Save weight somewhere else. You can still get to 2650 with driver.
I also had the FIA vertical bar added, after seeing how the front of a cage collapsed in a Spec Boxster roll-over accident at Willow Springs a few years ago.
In addition, I had a knee bar added and bars forward to the front shock towers.
Hope this helps,
Greg
Greg Holmberg is offline   Reply With Quote
Old 01-28-2016, 04:06 AM   #10
SpecBox
Yep that's pretty much what we found too, except in SCCA T4 we expect to have weight added and a restrictor, so it would push it into the 1-3/4" category.
Having said that, for SPB 1-1/2" is more than plenty for the weight of the car, based on 15+ years of hundreds of Spec Miatas racing at 2350-2450# with 1-1/2" .095 resulting in zero tubing failures, and that's with only 8 allowed attachment points.
Todd Lamb
Atlanta Speedwerks
Old 01-28-2016, 07:08 PM   #11
Josh also built my cage from the same materials with the FIA bar for added windscreen frame support.
There is no way that I would get into a race car with any less protection. We've seen what can happen...
Old 03-04-2016, 09:23 AM   #12
SpecBox
Working away getting this car done for Road Atlanta.
Wiring harness is out for redux.
Cage is done and headed to paint.
Todd Lamb
Atlanta Speedwerks
Old 03-06-2016, 05:34 PM   #13
SpecBox
24 days until Road Atlanta.
Finished up the cage in our shop on Friday, then sent the car out for interior paint over the weekend.
Assembly begins tomorrow, with lots of goodies from AIM, TuneRS, Pelican, and Tarett.
Todd Lamb
Atlanta Speedwerks
Old 03-10-2016, 04:13 AM   #14
SpecBox
21 days to Road Atlanta.
Engine ready to reinstall after bolt-on upgrades.
Front of car disassembled, radiators being cleaned.
Unboxed a bunch of parts, it's like Christmas (the most expensive Christmas)!
Todd Lamb
Atlanta Speedwerks
Old 03-10-2016, 05:21 AM   #15
rastta's Avatar
Looking good!
rastta is offline   Reply With Quote
Old 03-10-2016, 07:02 AM   #16
kk2002s's Avatar
Uh Uh - Lower control arms
Are those TRW? Very hard to get these days
Seal Grey
Old 03-10-2016, 04:15 PM   #17
What upgrades, exactly?
Old 03-13-2016, 01:13 PM   #18
SpecBox
Ordered from TuneRS, in stock.
Todd Lamb
Atlanta Speedwerks
Old 03-13-2016, 01:15 PM   #19
SpecBox
Low flow water pump, oil pump bypass, overdrive pulley, and 1000A alternator.
(Or....all the stuff the rule book allows)
Todd Lamb
Atlanta Speedwerks
Old 03-31-2016, 11:16 AM   #20
steved0x's Avatar
Did yo make it in time for Road Atlanta? Saw this guy heading north on I-75 this morning.
