Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 04-23-2014, 10:05 PM   #1
seningen's Avatar
Got my S back after suspension upgrade
Sourced a lightly used spec box setup
With some KWsports, 500# front and 650# rears
From various folks I picked up
A set of M030 sways, some tarrett rear drop links, tarrett camber plates, and new tarrett monoballs rear strut mounts.
Did a little tower dremmel mods to the front camber mounts.
Just got it back from the alignment shop
Pulling -2.8 degrees front camber and -2.3 rear camber.
New Dirrezza Ii's on rear to go with Dirrezza 1's up front
Installed Underdrive pulley, plumbed for oil pressure gauge (although I have to wire up the gauge still)
Felt really solid on the ride home.
Stiff for sure, but not intolerable.
Can't wait to hit the track and see how the upgrade performs.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 04-24-2014, 02:21 PM   #2
Sounds nice...pics?
Running adjustable rear toe arms?
jimk04 is offline   Reply With Quote
Old 04-24-2014, 05:09 PM   #3
seningen's Avatar
Originally Posted by jimk04 View Post
Sounds nice...pics?
No -- KW sports, M030 sway bar and tarrett drop links with
tarrett mono-ball spring supports.
No after pix yet
Here is a before with my DD and Tow vehicle.
Mike
Old 05-06-2014, 01:47 PM   #4
seningen's Avatar
Well crap -- took the Box S to my local track and had to replace 4 fillings and 3 ribs....
Ok it wasn't that bad -- but it was damn near undrivable.
My home track resembled a cow pasture when driving at speed.
I have to source some alternative springs --
Does anyone know what spring rate the original Boxster S is equivalent to?
I don't want to go quite that far -- but I can't drive with the 500/650 I have in there now.
thanks,
Mike
Old 05-06-2014, 04:08 PM   #5
LAP1DOUG's Avatar
thanks,
Mike
I measured the fronts at about 220 lb/in before I pulled them off the car, Resulting front wheel rate is about 180 lb/in. I didn't measure the stock rear, but would guess they are around 300 lb/in spring. They are progressively wound, so not linear though.
I am running 400 lb/in front / 500 lb/in rear now which works well on smooth race tracks (Barber & Road Atlanta) as well as relatively rough auto-x parking lot course. Good luck.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
Old 05-06-2014, 04:41 PM   #6
rastta's Avatar
What compression and rebound settings were you using? The Boxster I bought currently has 700/800 front/rear but has Moton shocks with a ton of adjustability. I'll be in it for the first time on track this weekend - looking forward to seeing how it is setup. I have setup notes from the previous owner - but not for the track I'll be on. I'm figuring I've got to start some place. It is also on full race slicks as well.
rastta is offline   Reply With Quote
Old 05-06-2014, 05:22 PM   #7
Track rat
Topless's Avatar
Stock springs are roughly 180F 250R
Stock PSS9 springs are roughly 260F/370R [ My car]
Boxster Spec are 450/500
Personally I think 450/500 is too much spring for a car with an open diff and often results in wheel spin on corner exit. Also way too stiff for street use with PSS9s. A more sophisticated dampener may be able to manage stiffer springs.
The voodoo is getting your tires, running weight, spring rates, dampeners, sway bars and driving style all working together to control your contact patch instead of fighting each other. Getting it exactly right is harder than it seems.
Old 05-06-2014, 07:49 PM   #8
Welcome to the wonderful world of suspension! Your education will start now and end....... uh, never.
My first suggestion is to set the shocks to full soft for compression and rebound. I have found that often the shocks cause a harsh ride rather than the springs. Then adjust from there.
If you look at all of the Spec Boxster setups, you will see a surprisingly wide variety. For example, Topless' suggestion to help put the power down on turn exit is to run a softer spring (which is fine), however I like to run a softer rear roll bar to try to soften the rear end in corners. This not only lets me get the power down on turn exit but also to keep the rear end planted if there are bumps. At the end of my last race, I even had a fellow racer even get down on his hands and knees to see where my rear bar was set because he couldn't believe how well I was able to drive away from him in some corners. The trade off (yes, there is almost always a trade off) is that I give up some roll stiffness and have to account for the additional roll in my driving technique. Same goal, but different approaches for different drivers.
I will admit that I have no experience with the KW's and they might react completely differently than the PSS9's. With that being said, my next best suggestion is to find a local shop that is familiar with racing and have them help set up the car. There is a fine art in balancing shocks, springs, tires, ride height, rake, tire pressures, etc., and one size definitely does not fit all. Paying someone with the right experience to get the car into the ballpark as a starting point might save a lot of trial and error ($$$) in the long run. Then you can work the fine adjustments on your own and always go back to the baseline.
Old 05-14-2014, 05:35 PM   #9
How about calling a few race-shops or placing a wanted ad on here for stock bilstein pSS-9 springs ?
You should be able to get a set as a cheap experiment .
There must be hundreds of spare sets gathering dust seeing as all the spec racers have bilsteins with quarter ton springs ......
Ian c is offline   Reply With Quote
