Old 08-06-2004, 10:38 AM   #21
We separate the ball joint where you have the red line because it is easier. We do not separate the ball joint where you have the yellow line.
Old 08-06-2004, 10:43 AM   #22
The bottom one is easier, and it will be one less thing to get in your way as it swings up with the top.
I have been running a K&N without any issues, I also have de-snorkled without issues.
K&N first then, sometime later De-snorked...
Just be careful with the amount of oil, be reasonable, I believe this is the culprit behind the K&N not working for people.
I did not really notice anything from my pants of the seat dyno from the K&N but I did notice some improvement from the De-snork...
The MAS is so close to the air filter, and it gets bombarded with oil when applied in excess.
If you are leery about the K&N and want the deeper sound, remove the foam from the stock filter.
I run K&N on everything, without any problems.
mrmickeymouse is offline   Reply With Quote
Old 08-09-2004, 12:34 AM   #23
acamachobadajoz's Avatar
YES!!!! this past weekend i had change my air filter (i´m going to do a picture album to share the change filter how to do..).
Thanks to all!!! friends!!!
And know....i´m going to find information to "how to change the spark plugs"
acamachobadajoz is offline   Reply With Quote
Old 09-15-2005, 10:06 AM   #24
Boxster Air Filter Change Help
Thank you to all of you who posted remarks on how to change the air filter on a boxster. YOu all came in very handy and it helped me out a lot. Best of luck to you all and thankyou again!
jdavis1735 is offline   Reply With Quote
Old 09-15-2005, 03:09 PM   #25
http://www.xclusivecar.com/Porsche_Boxster_S_Accessing_Motor.htm
2000 Porsche Boxster S
2007 Lexus RX350
xclusivecar is offline   Reply With Quote
