The bottom one is easier, and it will be one less thing to get in your way as it swings up with the top.
I have been running a K&N without any issues, I also have de-snorkled without issues.
K&N first then, sometime later De-snorked...
Just be careful with the amount of oil, be reasonable, I believe this is the culprit behind the K&N not working for people.
I did not really notice anything from my pants of the seat dyno from the K&N but I did notice some improvement from the De-snork...
The MAS is so close to the air filter, and it gets bombarded with oil when applied in excess.
If you are leery about the K&N and want the deeper sound, remove the foam from the stock filter.
I run K&N on everything, without any problems.
