Old 01-25-2007, 03:58 PM   #1
When it's cold
When it's cold i start my car the temp gauge blinks neat i think it's the 250 mark in red. The annoying part is i let it warm up then it stills stays on ... I have to shut the car then re-start it and it doesn't come back until the next time I start it or another cold day or if i let the car sit enough time where it gets cold again.
clb0099 is offline   Reply With Quote
Old 01-25-2007, 06:38 PM   #2
Owners manual says that the warning light can flash if the coolant level is low or a fault is detected with the engine compartment cooling fan.
wvicary is offline   Reply With Quote
Old 01-25-2007, 06:51 PM   #3
thank you.. i am going to bring it in to have the radiator flushed and put new antifreeze in. Cheaper to do it now rather then later when my radiator explodes LOL
Old 01-25-2007, 08:10 PM   #4
Lift the trunk floor and check for coolant to insure that the coolant reservoir isn't cracked. Also, make sure that the low coolant level sensor's electrical connector is properly seated...
Happy Motoring!... Jim'99
Old 01-25-2007, 09:55 PM   #5
got a picture of what ur talking about.. Cause i see to caps a blue one and another colored is that where th coolant is?
Old 01-25-2007, 10:15 PM   #6
The Blue Cap is your Coolant Cap. There is also a window for viewing the coolant level. This s/b between the MIN and MAX lines when the engine is COLD.
But, this reservoir is known to crack and leak. When this happens, coolant often collects in the Trunk Floor. The only way to see it is to remove the False Floor or lining. Under that, there is a plywoodbase, you want to lift that base and look for coolant. If found, you need to replace the coolant reservoir...
Old 01-25-2007, 11:11 PM   #7
is this DIY to replace the tank?
Old 01-26-2007, 04:35 AM   #8
edevlin's Avatar
When its cold, mine goes fast.........
Ed
:dance: :dance: :dance:
My Car Webpage
Old 01-26-2007, 05:20 AM   #9
Many have DIY'd it (and expanded their vocabulary in the process), but the access is limited and it's marginally complex. I'd rate it a 6 or 7 in difficulty. But, if you are experienced, and patient, it's easily doable, and you save a bundle...
