Thread: When it's cold
Old 01-25-2007, 10:15 PM   #6
MNBoxster
Originally Posted by clb0099
got a picture of what ur talking about.. Cause i see to caps a blue one and another colored is that where th coolant is?
Hi,
The Blue Cap is your Coolant Cap. There is also a window for viewing the coolant level. This s/b between the MIN and MAX lines when the engine is COLD.
But, this reservoir is known to crack and leak. When this happens, coolant often collects in the Trunk Floor. The only way to see it is to remove the False Floor or lining. Under that, there is a plywoodbase, you want to lift that base and look for coolant. If found, you need to replace the coolant reservoir...
Happy Motoring!... Jim'99
