Old 01-25-2007, 11:41 AM   #1
I have a leak, please help!
So I have a leak under the driver's side, I noticed the leak the other day when I pulled out of the garage. It is a blueish/green leak. Not sure what it is, probably coolent I suppose? Anybody with any suggestions? Thanks in advance.
Kenny
2000 Boxster
Ocean Blue Metallic
Full Savanna Beige Leather
Tiptronic, Sport Package, 18's
1998 Red Pontiac Tran Am
9.46 sec @146 mph
2005 Black Jaguar X-Type
Navigation, Subs, rims
BlueBox2000 is offline   Reply With Quote
Old 01-25-2007, 11:45 AM   #2
Well? What's in the car... Oil, Water, Coolant, PS fluid, Transmission fluid. From the description, it sounds like coolant. Did you check the coolant level? Notice a drop? Take a touch/smell of the liquid?
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 01-25-2007, 12:16 PM   #3
I won't be near the car until tonight, but I was thinking it might be windshield wiper fluid. The leak was under the driver's side on the ground. I didn't get to investigate, because I had to leave in a hurry.
2000 Boxster
Ocean Blue Metallic
9.46 sec @146 mph
Old 01-25-2007, 01:11 PM   #4
IIRC, the wiper fluid tank is in the front fender, drivers side - between the wheel and the door, as it were. Could be it.
1978 911 SC (sold)
Old 01-25-2007, 01:19 PM   #5
bmussatti
Guest
Posts: n/a
Yes, and it has an overflow drain to the outside. Maybe he overfilled it recently.
Old 01-25-2007, 08:26 PM   #6
Smell some of the fluid. If it's sickly sweet, it's antifreeze/coolant. If it smells like glass cleaner, it's wiper fluid.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
Old 01-26-2007, 07:36 AM   #7
If it is wiper fluid, then it could be similar to a problem I had. The hose that goes from the resevoir to the wipers had become disconnected. When I went to spray the windshield, about a half of gallon of windshield wiper fluid would hit the garage floor. If you pull back the fender inner plastic you can see the resevoir and associated hoses. I had to reach up in there and reconnect the hose then put a zip tie on it. Took about 30 minutes but has held now for over 6 months. Hope this is your problem...easy fix. Good Luck.
arp35 is offline   Reply With Quote
