Old 10-26-2025, 07:20 PM   #1
Registered Member
986 2.7 Camshaft Deviation
I recently got the dreaded check-engine light associated with camshaft deviation. The car is a 2001 base model (2.7) with about 135K miles. I've owned the car for about 5 years.
Of course it occurs just before my car's inspection is due. So I plugged in the Durometric tool, which showed the code P1341 (Porsche fault code 174 -camshaft adjustment bank 1 below limit value.)
After the car was warm, I used the Durametric to activate the camshaft solenoids while at idle.
- When I activated the bank 1 solenoid, nothing happened.
- When I activated the bank 2 solenoid, the engine's idle got very rough.
Next I took the Durometric and started data logging and took the car through my test loop, which is about 50% secondary roads, and 50% highway with a couple of engine pulls to redline on the entrance ramps.
I pulled the data out to Excel to see what is going on. First I compared the two camshaft positions to the the engine's RPM.
Than I compared the 2 sides to each other by subtracting the cam2 angle from the cam1 angle for each data point.
In both cases, it seams clear that camshaft 1 is generally about 2-3 degrees higher than camshaft 2, especially when they jump to the ~23 degree setting. Also the "Camshaft position 1 deviation" is obviously about -9.66 degree, but that seems to be more of a flag value that is set rather than a specific measurement. It stayed consistent throughout the test across all of the different engine conditions. The camshaft position 2 deviation is -3.86 degrees, and also consistent in all phases of operation.
Never the less, it seems like the camshaft 1 solenoid system isn't working (given the test at idle)
Is it possible and worth-while to replace bank-1 solenoid actuator to see if that fixes the problem, before I start down the path of pulling the engine and replacing all of the chains, rails, etc?
jluetjen is offline   Reply With Quote
Old 10-27-2025, 05:03 AM   #2
If it hasn't already been done, I guarantee you the adjuster pads are trashed and the chain is stretched. I've had one apart with only 106,000 miles and they were nearly thin enough to break soon.
-H. L. Mencken
Old 10-27-2025, 05:21 AM   #3
Registered Member
Yeah. I got it as far as the general fear factor. I had the oil tested a few years ago, and I've been cutting open the filter after each change.
The oil tested fairly normal, and there wasn't any colorful debris in the filter.
I'm thinking I'll start with another oil change and grab another sample for testing to see what they find. While I'm waiting for the results of that, I'll most likely try to do the accuator on bank 1 to see if it makes a diffeerence.. if iti fixes the prolem, and the oil and filter are nominal, good. If not, than 've only lost a couplebof weeks of time.
Old 10-27-2025, 05:28 AM   #4
To answer your question first, it is of course possible but I would change bank 1 against bank 2 solenoid to see if failure follows.
Newsguy's hint is also valid, there is a vid from LN-Engineering that shows how to replace these rails. My indie did that for me as well (same engine and mls) with engine in the car, no need to drop it.
You can verify it quite simple by pulling the oilfilter, cut it open and inspect it for brownish particles that point to these detoriated rails. After that replace filter + fill up housing with engine oil until filter is soaked with oil and level does no longer drop (~400ml) and install housing.
Old 10-27-2025, 10:08 AM   #5
Thinking some more about this. On the one I tore down, there was a lot of pad debris in the sump. Have you tried looking at that?
The pieces were big enough they dropped down directly and clogged the pickup. I also think a piece jammed the auxiliary pump in the head and wiped it out, as well as a main and rod bearing.
-H. L. Mencken
Old 10-27-2025, 08:04 PM   #6
Something seems off, because the actuator shifts at 2500 rpm and 5500 if i remember correctly, so all your data points below 2500 and above 5500 should fall around zero, while the data points between 2500 and 5500 should be around 23-24. That's clearly not the case.
However, I think both solenoids and actuators are working, because what happens is fairly similar between both banks. So, somehow, they are synchronously bad. Perhaps there's a broken wire somewhere which somehow affects both actuators.
For cam angle values over 20 the values clearly separate, which probably means one bank is not able to move the timing to the target range, probably because the chain pad is shot on that side.
Can you arrange the dataset in a time dependent manner?
Homeoboxter is online now   Reply With Quote
Old 10-29-2025, 06:46 PM   #7
Registered Member
Like this?
I think I see that you're saying.
1) They are clearly separated at the 20+ degree step. I'm guessing that it's the intake cam being advanced.
2) Also, it also doesn't look like they are moving together when they shift from the nominal 0 level the 20 degree+ level. This may be a time phasing issue since I wasn't taking a gazillion data points. It looks like the logger was capturing a data point every ~1.3 seconds.
But it looks like it's definitely the ramps.
I guess my project is now to replace them and run another set of data to confirm the solution.
Good point. It seems like the variocam is kicking in about 1000 RPM too low, and turning off about 500 RPM too low. Doing a web search, it looks like the actuation of the variocam is dependant on RPM and load. At lower engine loads, the actuation of the variocam is retarded. Under higher load (such as an entrance ramp engine pull) the actuation is advanced. Initially when accelerating from my driveway and a nearby stop sign, the load was high. Than I was cruising on a 2ndary road with 1 stop-light, in ~3rd gear, so no variocam was activated because the load on the engine was light.
It definitely seems like bank 2 is not advancing as much as bank 1. I guess the variocam system advances the intake cam by 13 cam degrees (or 26 crank degrees. I'm guessing the system measures everything in crank degrees). So the bank 1 intake cam appears to have lost about 1 degrees of advance, while bank 2 seems to have lost about 2 degrees of advance. So maybe bank 2 is the real problem(?). Or is it that both sides are retarded (i.e. 1/4-1/2 degree of wear on the tensioner ramps for the long chains, or the chains themselves), in addition to 1-2 degrees of wear on the variocam ramps?
Either way, I'm going to replace the variocam ramps on both sides while I'm under the car.
Old 10-30-2025, 06:43 AM   #8
Good luck doing that in the car. I’m finding it a bit of work on an engine stand! If you are able, I highly recommend you just drop it out. It’s pretty easy.
-H. L. Mencken
Old 10-30-2025, 10:05 PM   #9
Yes, plotting the cam angles in the function of time is more infomative. The graph looks fine, actually, apart from that separation in the high cam angle value ranges. I'm not sure about the load dependency, I usually check these in neutral. In those conditions, when revving the engine over 2500 rpm, the variocams keep the cam angle at around 25 degrees. So I would think your value (22) at bank 2 is showing a malfunction. Which is weird, because your fault code is at bank 1. But that code can be due to your high deviation value also on bank 1. Nevertheless, you need to pull both cam covers and replace all four pads anyways.
Old 10-31-2025, 08:24 AM   #10
Registered Member
Yes. I was thinking, why am I geetting alarmed for a Bank-1 error when bank-2 seems to have more wear?
Possibilities?
1. If you look at the "Actual Cam1-Actual Cam2" graph, you'll notice that the data is skewed towards the positive side. This suggests that cam1 is more likely to have a larger value than cam2. You can also see this in the distribution of points away from zero. I wonder if the Bank1 exhausr chain variocam unit is slow to return to 0 (and needs to be replaced).
2) Why does Cam1 have such a large negative deviation number when we don't see it in the numbers. My suspician is the Porsche may be more sophisticated than we give them credit for.. I suspect that "Deviation" is not just a reference name, but rather a statistical deviation calculated within the DMU. If this is the case, than enough data points far enough from the mean will trigger the alarm. I'll have to check this in the data when I get home.
Old 10-31-2025, 10:15 AM   #11
The Radium King's Avatar
cel shows up when deviation hits 9 degrees. if you have been tracking your deviation it is typically a slow degeneration until you hit the magic number. this is pads wearing and evidence is hard brown plastic in the sump.
if the solenoid fails evidence is green rubber in the sump (it's the seal that fails typically - always look to the plastic parts as your weak link as these cars age) and a drastic change in deviation - in my case to 16.
Old 10-31-2025, 10:58 AM   #12
Recall that there are at least 28 failure causes in this engine. Do em one at a time and spend your life or your savings. Try to do them all and do both.
Old 11-01-2025, 06:16 AM   #13
Registered Member
Disclaimer -- I've got the adjuster ramps, seals, cam adjustment tools, etc. on order. I'm also going to inspect the oil filter and get another oil test done.
Original problem statement: Check engine light (camshaft deviation) just as the car is due for its annual inspection.
My initial reaction?
... And then then I ( like many Porsche owners) was going spend the $,$$$ or potentially $$,$$$ to have the engine dropped and everything replaced, or worse sell the car for $ with the "check engine" light glowing.
Upon further reflection, I wonder if I was being too binary about the experience.
Sure. Ramps can fail and clog up oil passages. But let's give Porsche a little bit of credit. Not every car is a worst case. I also don't know if the ramps had previously been done on the car. For example, the IMS bearing had been replaced, but there was no clue of this nor a clutch replacement in the Carfax history.
Assuming that I don't see chunks of plastic in filter -- I think I may just re-align the cams, check everything again with the Durometric while I put the required 60 miles on the car and submit it for it's inspection. If the fault was due to "normal" wear, and there is adjustment left, and the check-engine light doesn't come back on, it should be fine for the immediate future.
All of this being said, since I've already paid for the tools and parts, I'm still going to take the cams out and replace the ramps, etc. But I may do it next spring when the weather is warmer and I have my 911 to drive around in.
As usual, I'll continue to post my findings and results on this subject on this thread.
Old 11-01-2025, 11:57 AM   #14
I'm afraid there's not much room for adjustment in this case. If you realign everything, that is going to affect primarily your exhaust camshaft and that's independent on the variocam. The variocam units adjust the intake camshafts only and there is no adjustment there. So, unless your long chains are badly stretched out or your chain has skipped a tooth already, you will find that the alignment is fine. But that does not mean the post variocam alignment is good, and that can't be adjusted.
Check pictures here for reference:
https://986forum.com/forums/show-tell-gallery/86442-meridian-boxster-rebuild-project-24-a.html
It's worth checking though, inspect the timing and let us know what you find.
Another thing you can try there is to inspect the chain pads with a borescope through the cam alignment holes. There's very little room to do this and you have to play a lot until you find the right angle, but that can give you a hint about the condition of the pads.
Good luck!
Old 11-01-2025, 01:05 PM   #15
Registered Member
I was thinking the same thing since I have a borescope.
Old 11-02-2025, 03:17 PM   #16
Registered Member
Good points. Not much of a benefit.
I just got the tools in last night. I'm ready to get started.
Old 11-03-2025, 03:03 AM   #17
https://youtu.be/ocntYwozZBY
Old 11-09-2025, 04:29 PM   #18
Registered Member
I finished some other projects on the car yesterday, and repositioned it so that I can now work on the engine. Before I unplugged the battery, I plugged in the Durometric again and this time just data logged as I rev'd the engine from idle up to at least 6000 RPM. That clarified the failure mode...
(I neglected to log the engine revs, but you can see the issue.) The bank 2 camshaft would pop right up to the advanced setting at 2500 RPM, but the bank 1 camshaft seems pretty lazy. Given enough time, it will get there, but it's significantly slower than bank 2. You can also see that when I let the engine revs fall, that bank 2 would jump to the advanced setting on the way down at 5500 RPM, and drop again at 2500 RPM, while bank 1 would barely get started. So it looks like it's definitely the actuator rather than the solenoid since bank 1's actuator is definitely getting the message, but it's just slow to respond.
Alas, the actuator and solenoid are replaced as a set. Why is this a problem? I just bought a solenoid, and now I had to buy an acuator+solenoid set. I'll see if I can return the unopened solenoid.
In other news, I cut open the oil filter from the last time that I changed the oil in the springtime, and found a couple (2, maybe 3) of these in the filter.
I drained the oil from the car yesterday and changed the filter again, but I haven't had a chance to open it. I also pulled a sample to have lab tested. I'll post what I find in the filter this time around in a couple of days.
Right now the plan is to replace intake chain, ramps and actuator subassembly on the bank 1 side, and the intake chain and ramps on the bank 2 side.
Old 11-09-2025, 06:58 PM   #19
It's also strange that the deviation on bank 2 is not steady. Looking forward to seeing what you find. Btw, the actuators are testable when they are out, and rebuildable as well.
Old 11-10-2025, 05:08 PM   #20
Registered Member
A turn for the worse
Here's the contents of the oil filter that I pulled out of the car on Saturday.
Greenish-yellow bits everywhere! My understanding is that this is from the seals of the chain tensioner. I guess there is no avoiding it -- it's time to replace the tensioner.
