Old 10-12-2025, 05:47 PM   #1
Chasing a steering wheel vibration ~70mph, could this be it?
I've been chasing a steering wheel vibration that shows up around 70mph. At this point I've replaced almost all of the suspension components ( they needed doing anyway ), had the wheels balanced 3 times, aligned twice, and it's not much better. Today on a whim I took a look at the tires and noticed that the front driver side tire looks like it might have a "hop" in it.
I grabbed a video of it here, is my mind playing tricks on me, or might this be the cause of what has been plaguing me for almost a year now?
BoxsterInTheSun is offline   Reply With Quote
Old 10-16-2025, 03:47 PM   #2
What is the condition of your front struts?
Gilles is offline   Reply With Quote
Old 10-16-2025, 03:51 PM   #3
Visually they look fine, not leaking. I suspect the previous owner added them at some point as they are Billstien B6 and the rears are the stock B4. The car has 137k on it, but I'm guessing the front struts don't.
Is there a way for me to "test" the struts to without removing them to know if they might be the problem?
Thanks for the help!
Old 10-17-2025, 01:37 PM   #4
With the car on the ground, push down on the quarter panel and see if you can rock/bounce the car back and forth. With my blown shocks it would rock and roll. With the new PSS9s it only moves about 1/2 up and down. Hard to push down.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
Danimal is online now   Reply With Quote
Old 10-17-2025, 01:40 PM   #5
Like Danimal suggests
Old 10-18-2025, 11:18 AM   #6
When you had your wheels (Tires?) balanced did you have them "Road Force" balanced????
