Old 03-24-2025, 08:22 AM   #1
My no-start last week was my clutch switch. Bypass the clutch switch to eliminate that. I found a really good youtube video for troubleshooting no-start that I saved, because it did a great job of walking through no-start troubleshooting.
https://youtu.be/ZSmehtE8Ctk
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
Old 03-24-2025, 04:34 PM   #2
You may want to check where the positive cable from the battery attaches into a plug on the firewall
Old 03-25-2025, 01:16 AM   #3
Originally Posted by professorman View Post
That's nice, cheers, I saved it as well. I wonder why he does not check fuse C3, because that is the immobilizer. The immobilizer itself has a fuse as well, you need to disconnect the battery first an then check that fuse. You at least have to loosen and tilt the seat for easy access....
997_986 is offline   Reply With Quote
