Old 03-23-2025, 10:00 AM   #1
Getting pops in exhaust at cold start during warm up
So I’m getting some fuel igniting in my exhaust. Hear some pops while it is warming up, but does go away after car is warm. No codes. Did have AOS go out and was replaced. Did it mess up my MAF sensor? I did clean it with MAF sensor cleaner. Should I replace? Thoughts? 2004 Boxster Base 72k miles.
Jbrews is offline   Reply With Quote
Old 03-23-2025, 08:02 PM   #2
The popping sound you’re hearing could be due to a few things:
1. MAF Sensor: If it’s dirty or failing, it can cause incorrect air-fuel mixture, leading to popping. Even after cleaning, it might need replacing if it’s faulty.
2. AOS Replacement: Double-check if the AOS was installed correctly. A vacuum or air leak from a faulty install can affect the air-fuel mixture.
3. Fuel Injectors/Ignition: Poor fuel injector performance or ignition system issues (spark plugs/coils) can cause unburned fuel to ignite in the exhaust.
Action: Test the MAF with a scan tool, check for any vacuum or exhaust leaks, and inspect the injectors and ignition system. If the issue persists, consider replacing the MAF sensor.
millerguzman183 is offline   Reply With Quote
Old 03-24-2025, 08:11 AM   #3
I just ordered the Bosch MAF from Rock Auto. It was the cheapest around and says it has a lifetime warranty. Not sure what that means, but I plan to bring my daily driver boxster to 250k miles+
BOSCH 0280218055 (0280218386), paid $142.79
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
Old 04-10-2025, 02:22 PM   #4
So i did replace the MAF and it didnt change anything.
I will check the AOS install as it was done recently. Crossing this is it!
Thank you!!
