Old 03-23-2025, 08:02 PM   #2
millerguzman183
The popping sound you’re hearing could be due to a few things:
1. MAF Sensor: If it’s dirty or failing, it can cause incorrect air-fuel mixture, leading to popping. Even after cleaning, it might need replacing if it’s faulty.
2. AOS Replacement: Double-check if the AOS was installed correctly. A vacuum or air leak from a faulty install can affect the air-fuel mixture.
3. Fuel Injectors/Ignition: Poor fuel injector performance or ignition system issues (spark plugs/coils) can cause unburned fuel to ignite in the exhaust.
Action: Test the MAF with a scan tool, check for any vacuum or exhaust leaks, and inspect the injectors and ignition system. If the issue persists, consider replacing the MAF sensor.
millerguzman183 is offline   Reply With Quote
