Old 06-01-2012, 06:05 PM   #1
vitaminC's Avatar
headliner is flapping
Another issue I've been having with my top relates to where the headliner comes down by the windows. It is loose, and there is an elastic band with a hook on the end that is hanging loose. I presume that should attach somewhere? They are undone on both sides, and the hook on the driver side is broken. Where do I reconnect them?
Passenger side:
Driver side:
'03 986S
vitaminC is offline   Reply With Quote
Old 06-02-2012, 12:01 PM   #2
copsahl's Avatar
They stretch and attach back under the clamshell. Put it in service position and take a look.
copsahl is offline   Reply With Quote
Old 06-02-2012, 12:31 PM   #3
dan.oneufer's Avatar
I have 2 that come off somewhat regularly. I agree it is probably from the stretching.
The broken one is probably a lost cause and will need to be replaced, but the other one will go back where it belongs with some coaxing. It hooks around the silver rod that runs east/west well down into the workings. It's really the only thing down there that is the right size to match the radius of that hook. It is supposed to be on the inboard side of that rod, with the hook coming from the back to the front of the car.
I connected an alligator clip to the end of a dowel to make it possible to keep it in the correct position and hook it around that rod.
I wish i could do a better job of describing it all.
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
Old 06-02-2012, 05:28 PM   #4
vitaminC's Avatar
Great info, thanks. I was able to reconnect the one that wasn't broken. Not sure what I'll do about the broken one, as replacing it would likely require some sewing skills. Probably I will just try to ignore it
'03 986S
Old 09-28-2014, 03:48 PM   #5
Bumping this to the top. Anyone have a better description of where these clip to? Both of mine are now uncooked and I've checked, cant seem to figure out where these clip to.
Old 09-29-2014, 06:19 AM   #6
steved0x's Avatar
I think one or both of mine are unhooked as well, I saw something like that floating around back there last time I was looking.
Old 09-29-2014, 07:41 PM   #7
Westwood's Avatar
I have never hooked mine back up because I could not see any obvious spot to do so. So if someone has really good camera skills I would like to vote for them posting this information as well! And thanks in advance for doing so!!!
Westwood is offline   Reply With Quote
Old 09-30-2014, 05:31 AM   #8
ep3_lol's Avatar
I'll put in my request for more information as well. This has been driving me crazy for more than a year and lengthy attempts to remedy the issue have been unsuccessful.
2002 Boxster 2.7
2008 Navigator L
ep3_lol is offline   Reply With Quote
Old 12-20-2017, 04:49 AM   #9
This is exactly what I needed! Thank you.
RichABoxsterS is offline   Reply With Quote
Old 12-20-2017, 05:02 AM   #10
kk2002s's Avatar
My right side keeps coming off. I use the left as reference to attach but it is almost impossible to manipulate the hook back into place. I fabricated a coat hanger with hook ends but man this is one of those spots
Seal Grey
Old 12-20-2017, 05:25 AM   #11
WALDMEISTER
BRAN's Avatar
My right hook came off, too.
Tried to look it up in the Bentley manual, but could not find anything.
So a modded coat hanger might be the tool...
Are there any pics of the attachment spot out there?
Old 02-25-2025, 07:40 PM   #12
Convertible headliner sail retainer clips
I designed a new clip for the headliner sails and printed it in polycarbonate. It is tough. Will update post with installed pics.
Keisler is offline   Reply With Quote
