Old 11-21-2024, 09:38 AM   #1
request assistance - circled item in photo
Hi All,
I have a burning oil smell, and upon inspection it looks like some of my spark plug tubes are weeping onto my exhaust, so at least that repair looks straightforward. Parts on order...
While looking for leaks, I started at the top of the motor and worked my way down with a flashlight, I noted I had a small thimble sized pool of oil on the top of the motor (not in photo), it looked like it was a bit oily around what I think is the oil fill tube where there is a clamp, so I wiped that up and I guess I will keep an eye on that in case it has a leak.
While poking around I then accidentally "pulled" a small diameter tube out of a "collar" fitting (circled in the photo). I re-inserted it, but after going through the manuals I have I can't identify what this tubing/connector is...any help appreciated.
I have a 914 which I am completely comfortable with but I am still learning my way around the boxster engine.
Car is a 2000 Boxster S that seems to be completely stock. Thanks, Reg
Skitch is offline   Reply With Quote
Old 11-21-2024, 10:04 AM   #2
Looks like the vacuum connction for the AoS.
Old 11-21-2024, 07:02 PM   #3
elgyqc's Avatar
Or the one-way valve for the vacuum system, small tube in the bottom left of the photo?
Grant
Old 11-21-2024, 07:17 PM   #4
Motorist & Coffee Drinker
78F350's Avatar
Pretty sure you're asking about the check valve.
Look at this thread: https://986forum.com/forums/boxster-general-discussions/69281-where-does-go-vacuum-valve.html
Old 11-22-2024, 11:06 AM   #5
Thanks everyone, much appreciated
