11-09-2024, 06:13 PM
I didn't realise I needed a new windshield...
... till I drove into the setting sun last week. There was so much pitting that it was very difficult to see out. I took this photo of the weird reflections I got. When not in direct setting (or rising) sunlight it was OK.
I had a new windshield installed this week... what a difference.
Grant
Reason: spelling
11-11-2024, 07:24 AM
Unfortunately, it's the same for me. I wait until i have a bigger damage that justifies the removal. Because you have to find a company that does it according to the P-regulations. If you tell them that neither the rear-view mirror can be installed nor the windows closed before a waiting time of minimum 3h and they nod and smile, you're fine. You have to avoid those who look at you in disbelief.
11-12-2024, 04:50 AM
1998 Boxster Silver/Red
Why?
I've a winddshield that is going to be replaced and... while I trust my 15-years+ glass guy... I'd like to know.
Thanks.
1998 Porsche Boxster
11-12-2024, 05:13 AM
Porsche's instructions explicitly stipulate a waiting time of 3 hours after applying the adhesive before the windows can be closed and the rear-view mirror can be fitted. While the mirror is obvious I understand the point about the windows (with the door closed), because they "brace" the door/frame system. If it is allowed to harden in the "stressed" state, it makes a difference later in operation.
I don't know if you can tell the difference, but it is explicitly stated in POSES and thus makes the difference to an improper work. Btw, the 996 + 997 windscreen change instructions stipulate the same.
11-13-2024, 03:14 AM
Registered Member
All that I see in POSES on the topic is what’s below. Nothing about mirrors or windows, just the 3 hour cure time.
Danger of material damage if specified curing time of adhesive is not observed!
The vehicle must not be used until the curing time has elapsed.
In order to ensure that the bonded joint is sufficiently strong, the following boundary conditions must be adhered to:
Curing time: 3 hours
Temperature: at least 10°C
Fixing time: approx. 1 hour
Tom Coradeschi
03 Boxster
11-13-2024, 03:38 AM
You have to read to the end. The important inormation is mentioned before the tools to be used, point 10 and 11.
11-13-2024, 06:34 AM
What is "POSES" ?
98' Boxster
11-13-2024, 07:51 AM
It is a "workshop manual" that provides detailed repair information.
The introductory sentence is:
"The available data includes technical information, descriptions of repair work on Porsche vehicles and training literature. The descriptions are intended exclusively for workshops and their workshop personnel."
11-13-2024, 11:44 AM
Multi-Boxer Driver
Most likely that the wait is to prevent outward forces on the glass prior to adhesive set.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
11-14-2024, 03:13 AM
Registered Member
You are correct! How about that…
FWIW, the shop which replaced mine certainly didn’t let it sit for 3 hours. That was ~4 years ago, and, aside a fresh set of chips (the car is a year round daily driver), nothing negative to report.
Tom Coradeschi
03 Boxster
11-14-2024, 05:48 AM
I need a new windshield in my Cayman, as it's been sandblasted by track use and winter beater duty. Even has a pinkie sized chip that I've fixed myself. But I've been reluctant to change due to the stickers from various tracks that I'd lose - 4 COTA, an Indy, and a Kansas Speedway. Two from 2015 and two from 2016. At some pt I'll have to replace it but I'm going to hold on as long as I can. Might have to go w/ track maps on the rear window then.
1989 928 S4 5 spd - black
11-14-2024, 07:26 AM
The shop that I used didn't wait 3 hours either. They did put masking tape over the molding at the top and sides and instructed me to leave it on for a day and not to wash the car. It strikes me that the POSES instructions discussed here were likely issued at least 20 years ago for the Porsche products used at that time. Dare I suggest that the adhesives used today are totally different?
Grant
