Originally Posted by blinkwatt
How would you properly connect the wires?
Hi,
If using Universals, I would eliminate the connector altogether and simply splice the two wires together using some Hi-Temp Shrink Wrap or Tape. This will allow the air to enter the wire sheathing and be used by the sensor. You could also carefully make a few pin holes in the sheathing. Just so long as you don't cutoff the Reference Air supply to the sensor...
Happy Motoring!... Jim'99
