Old 07-23-2024, 08:24 AM   #1
Reply to Thread - Cooling upgrade suggestions
Yo, sounds like your Boxster’s got some overheating issues going on. Climbing mountains in hot weather can definitely test its limits. You've got the water pump and thermostat on deck, which is solid.
Upgrading to a thicker radiator is a good move, check out brands like Setrab or CSF for reliable options. Since you’re already cleaning debris and adding mesh, you’re on the right track.
If you're keen on extra reliability mods, maybe consider upgrading the coolant hoses and checking the radiator cap.
Keeping things cool and tight is key to avoiding future headaches.
Frasta is offline   Reply With Quote
Old 07-24-2024, 10:04 AM   #2
Nickanator8's Avatar
Thanks for the reply. I've struggled to get consistent/reliable information on the thickness of the OEM vs aftermarket radiators. Do you have any firsthand experience with either of those brands?
Cliffy, 2000 Porsche Boxster S Tiptronic - The Sportscar Utility Vehicle
Nickanator8 is online now   Reply With Quote
