Old 06-11-2024, 02:02 PM   #1
Shifter Cable Clip
Can someone help me find the part # for this clip?
Thanks,
E-
ecruz is offline   Reply With Quote
Old 06-12-2024, 07:00 AM   #2
Looking at the part diagrams it doesn't list that as a separate part, from what I can see:
Might have to see if anyone on the forum has spares?
redpepperracing is offline   Reply With Quote
Old 06-12-2024, 08:23 AM   #3
Interesting...the instructions I saw said to always replace the clips with new ones, since they're "cheap and easy to find". Well, I've been unable to find them.
Maybe I'll be able to reuse the once that I remove. Just figured I'd put new ones on, if I could.
Thanks for your help.
Old 06-12-2024, 12:11 PM   #4
I imagine the reason to replace would be if they loosen over time, I wouldn't worry about steel retaining clips on a plastic assembly being damaged or fatigued.
If they're a bit loose, I'd just gently tighten them with pliers. I've done that with spark plug leads and other similar stamped bits that need to be tight before, with great success.
S50Sinner is offline   Reply With Quote
Old 06-13-2024, 12:09 PM   #5
Thanks, S50Sinner
Old 06-17-2024, 08:52 AM   #6
Turns out the design on my car was slightly different. It didn't have the metal clips.
