Old 06-12-2024, 11:11 AM   #4
S50Sinner
I imagine the reason to replace would be if they loosen over time, I wouldn't worry about steel retaining clips on a plastic assembly being damaged or fatigued.
If they're a bit loose, I'd just gently tighten them with pliers. I've done that with spark plug leads and other similar stamped bits that need to be tight before, with great success.
S50Sinner is offline   Reply With Quote
