03-27-2024, 01:44 PM
#21
yep....several from small to tiny all very short.
98' Boxster
03-28-2024, 01:19 PM
#22
Remove vent next to ignition switch first
For me this was easier access than under the dash.
David
03-28-2024, 05:20 PM
#23
Originally Posted by Luckyman01
Remove vent next to ignition switch first.
David
A number of folks agree with you, David. I think I'm convinced. I wasn't looking forward to shoehorning myself into the footwell.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-29-2024, 01:00 AM
#24
03-29-2024, 03:24 AM
#25
I changed the ignition switch from underneath the dash and found it to be fairly easy task with the exception of messing around with my eyeglasses to see what I'm doing
2001 996 C2 Manual
03-29-2024, 07:44 AM
#26
Deleted post.
98' Boxster
03-29-2024, 01:56 PM
#27
Originally Posted by Spinnaker
Thank you very much for the link. Very informative. I'm about ready to attempt it.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-29-2024, 01:59 PM
#28
Question: Since the switch is part of the electrical system, is it necessary to disconnect the battery first?
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-29-2024, 03:32 PM
#29
That would be a very good idea.
03-29-2024, 06:32 PM
#30
Then I'm glad I disconnected the negative terminal and insulated the cable end in a plastic bag. Thanks for the confirmation.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-29-2024, 07:49 PM
#31
I managed to get the task half-finished before I had to knock off for the day to attend to something else. First, I removed the driver's side vent, which indeed provides better access to the switch. Then I unplugged the wiring harness connector from the back of the switch and had just enough time remaining to loosen one of the set screws (see photo). Even with access through the vent, getting a small screwdriver on those screws is a challenge, I kid you not. Wrapping things up will have to wait until tomorrow. I hope it's not a godawful thrash to get it back together.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-30-2024, 07:26 AM
#32
So???? How did it go?
After you finished the job (assuming you did) and looking back on the job, would you advise me to go through the vent or from under the dash?
Another question: IF going through the vent, can you access BOTH set screws or do you need to go below the dash to access the other set screw? (in other words from BOTH positions depending on which set screw)
Ideally it would best to BOTH set screws from the vent but "ideally" isn't always possible.....lol
98' Boxster
03-30-2024, 08:15 PM
#33
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-30-2024, 09:05 PM
#34
Motorist & Coffee Drinker
Here's the Pelican parts Tech Article: https://www.pelicanparts.com/techarticles/Boxster_Tech/86-ELEC-Ignition_Switch/86-ELEC-Ignition_Switch.htm
Here's a part of it that may be helpful to you:
Edit... just for fun, I checked the link to the part that Pelican showed. It is NLA.
Try This: 4B0-905-849
03-30-2024, 11:10 PM
#35
I just now ordered this switch from Amazon, a 4B0-905-849, which is identical to the one I took out:
https://www.amazon.com/URO-Parts-4B0-905-849/dp/B0066SFX1Q/
It won't get here until Wednesday, which is fine with me. It will give me time to recuperate from the past couple days' contortions and psych myself up for the ordeal ahead. I've completely rebuilt several automobile engines, one transmission, and two overhead-cam motorcycle engines, but replacing this switch is by far the most challenging mechanical project I've ever attempted, due solely to the inaccessibility. It can give you nightmares about being trapped in a claustrophobically tight place. Maybe the second one would be easier... and I hope to hell there won't be a second one.
But I'm not one to complain.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-30-2024, 11:31 PM
#36
I'm only half-finished, but I can answer your questions. Yes, you can theoretically access both set screws through the vent opening -- but I couldn't manage it, and Lord knows I tried. I ended up upside down in the footwell again to get the second set screw out. Maybe you'd have better luck. Some folks have supposedly pulled it off. But if I had to do it over again, I probably wouldn't remove the vent.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-31-2024, 09:00 AM
#37
My hat's off to you, fellow pilot. Maybe my 986 has it in for me. The main problem I had was breaking those *^%(=@$! set screws loose. They were exceptionally tight and I couldn't apply enough torque to the tiny screwdriver with my thumb and index finger. Perhaps some testosterone would've helped, but I didn't want to start shaving my face.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-31-2024, 09:09 AM
#38
Thank you for the helpful links. Unfortunately, I couldn't see the part number until I got the switch out. Amazon's "This part will fit your car" assurance cannot be depended on.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
03-31-2024, 09:59 AM
#39
Amazon goes by what the manufacturer states, which in this case (URO) is an unreliable one........
03-31-2024, 10:13 AM
#40
Tell me about it.
JFP, if I may, I'd like to ask you a question. Other folks have replaced the switch without encountering the difficulties I did. Am I just a wimp, or what?
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
| Thread Tools |
| Display Modes |
Linear Mode
