Old 07-03-2023, 06:34 AM   #1
Change water pump and thermostat - tips/tricks?
Just about the change my water pump and thermostat (using a low temp replacement).
Is the sealing ring for the coolant drain the same size as for the oil pan plug? If not, does anyone know the part number?
Thoughts on flushing with distilled water after draining the coolant?
Looks like a lot of people use something like this to remove the hoses from the thermostat and water pump
Any other suggestions?
s_wilwerding is offline   Reply With Quote
