Old 07-03-2023, 06:34 AM   #1
Change water pump and thermostat - tips/tricks?
Just about the change my water pump and thermostat (using a low temp replacement).
Is the sealing ring for the coolant drain the same size as for the oil pan plug? If not, does anyone know the part number?
Thoughts on flushing with distilled water after draining the coolant?
Looks like a lot of people use something like this to remove the hoses from the thermostat and water pump
Any other suggestions?
s_wilwerding is offline   Reply With Quote
Old 07-03-2023, 07:08 AM   #2
1998 Boxster Silver/Red
Park the car on an incline, nose first, so gravity assists the draining process.
Consider replacing the motor mount at the same time. Makes the "fifth" pump bolt easier to navigate.
Flush? Nah.
Approach it like it's NOT a Porsche, and you'll be fine.
In conclusion, and because this topic has been covered a billion times... do more reading. More. I.E. Seek and ye shall find.
1998 Porsche Boxster
Old 07-03-2023, 07:20 AM   #3
Wrong tool for removing the hoses, you should have one of these:
You insert one of these under the hose to work it loose. Amazon sells them and they work on any hose.
You should also get a piece of cardboard the size of the water pump, and mark and label the various bolt holes in the replacement pump. Then, as you remove each bolt, insert it into the matching hole in the cardboard, that way you will know which bolt goes in which hole. Not all the bolts are the same, and the most common DIY water pump failure we see is mixing up the bolts.
Old 07-03-2023, 09:37 AM   #4
78F350's Avatar
It is best to use a metal gasket that comes with a coating like the original gasket - these require no sealant. If you use a fiber gasket with with sealant, use a minimal amount of sealant - excess sealant can break off after it hardens and get stuck in the small coolant passages in the head.
For draining coolant. I typically drain it directly from the hose on the thermostat when I disconnect it. I use a plastic storage tub underneath the car to catch all of the coolant when it drains.
Many people will also replace the engine mount while they are doing the water pump. It's located in the same area and it is easier to reach all the bolts while the engine mount is removed.
Old 07-03-2023, 06:34 PM   #5
True, but IIRC all of them are the same size except one. Just make sure to keep track which one that is. The others are interchangeable. (I'm speaking based on my experience with mine, a 2001. While I think they're all similar, it's conceivable that other 986s differ. Just keep track as you take them out.)
Old 07-04-2023, 11:06 AM   #6
78F350's Avatar
This is my belief:
Old 07-05-2023, 07:59 AM   #7
This is correct
Radman is offline   Reply With Quote
Old 07-05-2023, 03:28 PM   #8
That's almost certainly right, I stand corrected.
I remembered there was a reasonably easy way of keeping track where the long bolt(s) went...and I believe that's what it was: ie where those sleeve extensions are. I had thought it was just one, but looks like there are two.
Good call.
Old 07-05-2023, 07:51 PM   #9
No, coolant drain plug is much smaller, part # 900 123 144 30.
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
nuvolari is offline   Reply With Quote
Old 07-06-2023, 03:50 PM   #10
Completely agree. Those pics are the right tools.
Bush Pilot is offline   Reply With Quote
