Old 05-15-2023, 08:16 PM   #1
Won’t crank
2002 Porsche Boxster 986. Started getting a fuel smell through the vents. The next day it will not start. I have a ignition switch coming and it will be replaced end of the week. I was going to check the fuse in the immobilizer, check the relay, check voltage going to the fuel pump before I order one. Any other ideas I’m missing. The fuel smell from the vents is while in motion not a smell just from sitting around.
Only codes are P1128 and P1130
Bsxtaylor is offline   Reply With Quote
Old 05-16-2023, 05:48 AM   #2
1998 Boxster Silver/Red
What in the world are you driving?????
1998 Porsche Boxster
Old 05-16-2023, 07:28 AM   #3
Sorry. Edited post. 2002 Boxster 986
Old 05-16-2023, 07:41 AM   #4
Codes indicate that one or more of the following is happening:
-Incorrect MAF signal
-fuel pressure too high
-injector leaking
-EVAP cannister purge valve stuck open
Old 05-16-2023, 09:20 AM   #5
The Radium King's Avatar
fuel smell through the vents would suggest the fourth - evap cannister ... ?
Old 05-16-2023, 09:56 AM   #6
So would the middle two..................
Old 05-16-2023, 10:54 AM   #7
apologies yes, i was thinking the purge valve lived up front with the charcoal cannister, etc.
Old 05-16-2023, 11:34 AM   #8
I will have to look those up. How do you check them. And would it make it not crank as well?
Old 05-16-2023, 11:47 AM   #9
You need to do some online searching, each has its own diagnostic tree..............
