Old 11-26-2006, 08:16 AM   #1
Miscellaneous questions
1) I ordered rear speakers from PNP for my 2000 Boxster; I have 2 old amps (Sony xm-21+xm-41) from an old stereo. They both have some kind of 10 pin round connector. Is it worth it to try to use one of these, and how would I hook up?
2) Should I fill the speaker cavity with loose pillow filling, something else, or keep empty?
3) Should I wire speaker harness through right side of tunnel i/o the door sill (seems easier and no need to disconnect battery), and does anyone have instructions for doing so?
4) I was trying to pick up switched 12 volts and ground from the fuse box for a radar detector and was trying to find an easy way of doing this. As you can tell, I'm not very good at this stuff.
Thanks in advance for the help.
milist is offline   Reply With Quote
