04-05-2023, 07:50 AM
#1
'99 Boxster Tiptronic not firing after engine overhaul
Hi,
my 1999 Boxster 2.5 l Tiptronic does not start (fire) after engine overhaul.
The starter cranks the engine ok, but it does does not fire. I went through the list of usual issues to look out for including the following:
- installed new CPS (reads 880 Ohms) seated correctly
- installed new ignition switch
- installed new fuel pump relay, which clicks when the key is turned (however, pump is not coming on then)
- Fuel pump engages and pumps fuel when relay is jumpered (but not when key is turned)
- MAF connector and ignition coil connectors have +12 V when ignition is on
- All fuses (next to pedal) are good
Here is what I observe:
- the engine cranks, but doesn't fire
- The rpm needle does not move when the starter cranks the engine
- No smell of fuel at the exhaust after cranking
Is there a specific relay that powers the injectors and prompts the ignition sparks that could be blown?
Thanks for any thoughts!
04-05-2023, 09:21 AM
#2
If the DME is not seeing the engine turning signal from the CPS, it will shut off the fuel and ignition.
04-05-2023, 10:18 AM
#3
Been awhile since I have been down this road.
There is a relay in the back left side of the trunk which I think sources the gnd for the fuel pump relay and the ignition coils.
Any chance the immobilizer got wet? similar symptoms.
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
04-05-2023, 10:52 AM
#4
Thanks for the quick feedback!
CPS: Though it's brand new (Pelican) and no sign of not working (tests alright), I will get another new one to be absolutely sure it's not that.
Immobilizer: Car was in garage for past 3 years so can exclude that it got wet. Also: would the immobilizer not prevent the engine from cranking in the first place?
Will check the relays in the back.
04-05-2023, 11:45 AM
#5
Long before aimlessly throwing parts at it, why not check and see if the DME is getting a signal from the CPS? Trace the CPS wires to the connector at the DME and look for a low voltage signal on them at the DME end when the engine is turning over; if you have a signal, it isn't the CPS.
04-05-2023, 01:23 PM
#6
Thanks! Is there a chart for the pins in the DME plug? Or is it best to go by the color coded cables from the CPS?
04-05-2023, 01:39 PM
#7
Service manuals will have a complete wiring diagram.
04-05-2023, 03:15 PM
#8
If you have Durametric or other Porsche specific OBDII scanner you should be able to view RPM while cranking (expect around 75-100 RPM) that would tell you if the DME is receiving a signal from the CPS or not.
04-05-2023, 03:27 PM
#9
Motorist & Coffee Drinker
Maybe pin 78..?
I have a link to this in my folder of DME stuff, Says it's DME 5.2.2: https://www.renntech.org/topic/28597-porsche-996-dme-pinouts-and-connectors/
04-07-2023, 04:47 PM
#10
Thanks. I checked the relays in the trunk per Bentley manual and they all seem ok.
I also measured the voltage directly from the CPS connector when cranking the engine and it clearly produces a signal. So the CPS seems to be fine.
I am however unclear how to check if that signal reaches the DM, because when I disconnect the DME connector to check for the signal on the respective pins the car will not start at all. I guess need to jumper the starter for that test?
04-07-2023, 05:07 PM
#11
Use a Multi Meter to check continuity and for short to ground on the respective pins
04-07-2023, 06:17 PM
#12
No, the CPS is a Hall Effect sensor, it only has to turn over to generate a signal, it does not need to run.
04-07-2023, 06:43 PM
#13
Understood, but how do i get the flywheel to turn with the DME (and hence the starter) disconnected so i have access to the DME connector pins?
04-08-2023, 08:36 AM
#14
The starter should still turn over with the DME unplugged, but if not, reconnect it and back probe the pins on the DME harness plug.
04-08-2023, 10:38 AM
#15
Resolved
Many thanks for the good advice !
I checked continuity for the CPS wires on pin 20 and 78 on the DME connector and there was none. I then realized that the connector for the camshaft position sensor has the same profile as the CPS connector -- and sure enough they were swapped. With the right connector on each sensor the engine started up rightaway!
For now its only runs on cylinders 1/2/3 - but i guess I should revisit all connectors on that side as well and then take it from there. Thanks again!
