Old 02-22-2023, 09:43 AM   #1
Sounds Great But No Power
Hello,
I am have a 986 2.5 1997. The people before me must have hated the car. Fuel pump hooked up with thin speaker wire and a switch inside the car. Fuel filter was by passed with a tiny little filter. The car is an automatic. The things i have done .Original problem was the water reservoir. So new water reservoir, repair the damage to the wiring and new fuel pump and filter (oem). New plugs , coils, tubes, new ecu . I have cleaned the throttle body and maf.
The car runs and sounds great (being i have never heard one before). It doesn't smoke or smell odd.
When i try to drive it . moves but no power maybe gets up to 15mph. All the covers are still off so i don't hear any odd with the engine.
Scanned with a Autel ms908pro. no codes.
109000+- miles on it
please help
Offdepp is offline   Reply With Quote
Old 02-22-2023, 10:58 AM   #2
piper6909's Avatar
Does it bog down when you rev it in park or neutral? If so, maybe your cat is clogged?
2010 Subaru Forester
piper6909 is online now   Reply With Quote
Old 02-22-2023, 11:05 AM   #3
Originally Posted by Offdepp View Post
Hello,
I am have a 986 2.5 1987. The people before me must have hated the car. Fuel pump hooked up with thin speaker wire and a switch inside the car. Fuel filter was by passed with a tiny little filter. The car is an automatic. The things i have done .Original problem was the water reservoir. So new water reservoir, repair the damage to the wiring and new fuel pump and filter (oem). New plugs , coils, tubes, new ecu . I have cleaned the throttle body and maf.
please help
First:.... They didn't make a 986 in 1987 so please give the correct year.
Second...... how many miles???? Automatic or standard transmission??
Third..... do you have a check engine light on? if not are you sure it works?
Forth......scanner the DME/ECU with a OBDII scanner and look for any codes.
Permanent and pending.
The car may be in limp mode. Perhaps someone on the forum knows how to tell if that is the case.
Old 02-22-2023, 11:38 AM   #4
Thanks for the heads 1987 was a slip of my finger. I have edited the post.
thanks again
Old 02-22-2023, 11:40 AM   #5
thanks again
Old 02-22-2023, 11:47 AM   #6
I have not tried that yet.
Thank you
