Old 02-22-2023, 11:40 AM   #5
Offdepp
First:.... They didn't make a 986 in 1987 so please give the correct year.
Second...... how many miles???? Automatic or standard transmission??
Third..... do you have a check engine light on? if not are you sure it works?
Forth......scanner the DME/ECU with a OBDII scanner and look for any codes.
Permanent and pending.
The car may be in limp mode. Perhaps someone on the forum knows how to tell if that is the case.
Thanks for the heads 1987 was a slip of my finger. I have edited the post.
thanks again
Offdepp is offline   Reply With Quote
