Old 02-16-2023, 05:58 AM   #1
Casual Driver
Exclamation Coolant Leak - Passenger Side
Hello everyone, finally got round to making an account here
I'll get straight to my issue; I have a problem with my 2004 Boxster S 986 3.2 regarding a coolant leak. Occasionally coolant will leak into the passenger side in the cockpit. It seems to seep out from the middle part of the car (I have attached an image). I'm not sure if this has anything to do with the heater core. However, occasionally my windscreen tends to condensate quite a lot too and I'm not sure if this is related. My drainage tubes seem to be clear so that doesn't seem to be the issue causing my condensation.
I'd appreciate any help with this. Thank you all!
Image of leak;
jamesmartin986 is offline   Reply With Quote
Old 02-16-2023, 06:26 AM   #2
Leaking heater coire.
Old 02-16-2023, 07:35 AM   #3
seningen's Avatar
Image of leak;
There are some videos out there talking about how to repair the blend doors via going underneath the battery tray -- this is where the heater core is and looks fairly easy to get to-
Mike
mike@lonestarrpm.com
Old 02-16-2023, 07:52 AM   #4
1998 Boxster Owner
+1 when mine failed passenger side was wet
Benitom is offline   Reply With Quote
Old 02-16-2023, 09:05 AM   #5
Casual Driver
Mike
I remember watching a video with the process on how to get to it, so it seems pretty straight forward. I read that you could also get to it through the center console by taking the A/C and Radio units out, but it required snapping a piece of plastic, which I'd prefer not to do.
Seems a heater core will be making its way onto my shopping list.
Old 02-17-2023, 03:03 AM   #6
Casual Driver
So, I have ordered a new Heater Core, but won't get here for a couple of weeks. As a temporal solution, is it possible to disconnect the two hoses from the old heater core and put them together? Hopefully that'll stop my leaking until the new one arrives.
Porsche Boxster S 986 3.2 | Manual | Midnight Blue
Old 02-17-2023, 05:54 AM   #7
Multi-Boxer Driver
Deserion's Avatar
Either using a hose pinch clamp or connecting them together would work, yes.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 02-17-2023, 07:59 AM   #8
Casual Driver
Thank you!
Tags
boxster 986 , condensation , coolant leak , issue
